Old 08-15-2012, 05:00 PM   #1
Double breakers
How many double breakers "space saving" can you have in an electrial panel.
Kidneyking is offline   Reply With Quote
Old 08-15-2012, 05:01 PM   #2
E2 Electrician
stickboy1375's Avatar
Double breakers
IF any, it would be listed on the panel.
Old 08-15-2012, 05:05 PM   #3
Licensed electrician
Double breakers
Some would be 0, others could be up to 20. Look at the panel label.
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires? tjnoff Electrical 77 04-17-2013 12:23 PM
Arcing between circuit breakers and flickering lights mscotter Electrical 12 07-13-2012 01:46 AM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 08:07 AM
40 amp double pole gfci problem rivers Electrical 38 07-19-2008 01:10 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
