Double Breaker Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 08:52 PM   #1
double breaker wiring
how do i hook up a doublebreaker to a single plug for a stove do you split the main wire i need help please een if you know a little bit about this stuff
palmerg31 is offline   Reply With Quote
Old 09-13-2011, 09:01 PM   #2
Licensed electrician
Rewards Points: 1,770
For a stove in the US you would have two hots, 1 neutral and one ground. The 2 hots would go to the breaker.
palmerg31 (09-13-2011)
Old 09-13-2011, 09:03 PM   #3
jschaben
Rewards Points: 502
HI - With all due respect and concern for your safety and my peace of mind, I repectfully suggest you call an electrician. If I understand your circuit description you are likely dealing with a 220 Volt-30 to 50 amp circuit which is more than able to deal lethal blows. What I'm really saying is, "if you need to ask that question, you need to call someone".
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 09-13-2011, 09:12 PM   #4
yeah its two ffity breakers for the double breaker
Old 09-13-2011, 09:14 PM   #5
jim port your a electrician does this sound right the black and white to the breakers and the ground wire to the ground bar thats what i found out
Old 09-13-2011, 09:15 PM   #6
Code05's Avatar
Rewards Points: 1,104
I gots 240v at me breaker, is I safe. Don't I gotta touch both hots to get popped by 240v. What are the odds?
Code05 is offline   Reply With Quote
Old 09-13-2011, 09:17 PM   #7
Code05's Avatar
What size wire?
Old 09-13-2011, 09:18 PM   #8
Code05's Avatar
Why is this not a 4 wire feed?
Old 09-13-2011, 09:19 PM   #9
You do not have enough wires in order to do this safely or to code. I don't know where you found that information but it is inaccurate.
I too am going to suggest you hire a licensed professional.
Old 09-13-2011, 09:21 PM   #10
Code05's Avatar
No argument there.
Old 09-13-2011, 09:22 PM   #11
Rewards Points: 160
Ok, he just told you, you need 2 hots, 1 neutral, and 1 ground. That's 4 wires; black and red to hot, white neutral, green/bare ground. If you don't understand the difference between 2 and 3 wires, seriously, call an electrician.
matt151617 is offline   Reply With Quote
Old 09-13-2011, 09:36 PM   #12
i got it i have four wires noi need to be a smarty pants my bf had worded it to me wrong i was trying to find out for him while he contnued to work so he would not have to quit and yeah we do have the wires hooked up right according to jim port thanks alot i really appreciate your help i was the one that had made the mistake and worded things wrong
A/C wiring manual says 14 awg & 20 amp breaker? brianosaur Electrical 13 06-17-2011 03:57 PM
double switch wiring problem avalanchehunter Electrical 5 12-13-2009 01:00 PM
Single breaker vs double pole breaker for MAIN tuckerz Electrical 11 11-16-2009 06:42 PM
breaker box wiring rick32 Electrical 8 11-29-2007 11:11 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
