Double 15 Amp Single Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 02:11 PM   #1
Double 15 amp single pole
I need to free up a pole on my 200 amp panel. There are several 15 amp single pole breakers that feed bedroom plugs & lights. Is it possible to use a double 15 amp single pole breaker to free up a pole?
mmacnz is offline   Reply With Quote
Old 04-17-2011, 02:21 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
don't know. What is the manufacture and model of the panel?
Old 04-17-2011, 02:58 PM   #3
Rewards Points: 27
Model number and make of panel needed. Putting one of those breakers into your panel be impossible if not outright illegal.
kossuth is offline   Reply With Quote
Old 04-17-2011, 04:12 PM   #4
It's a Siemens - EQ Loadcenter
Old 04-17-2011, 04:14 PM   #5
Old 04-17-2011, 04:53 PM   #6
nap
You talking to me?
nap's Avatar
we need more than that. What is the exact model?
Old 04-17-2011, 09:11 PM   #7
" Euro " electrician
frenchelectrican's Avatar
You have to understand why we ask for modél number of this load centré due we can able determed if this load centré is legit to take tandam or quad breakers.
The modél number is located either front cover or inside of the load centré tub it will be either on right or left side of it and get full model number we will go from there to determed if that is legit to use it or not.
Merci,
Marc
Type nc single pole breakers to type na single pole Wiley Electrical 7 12-02-2010 10:33 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 08:14 AM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 02:44 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 09:20 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
