Doorknobs And Light Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 03:14 PM   #1
doorknobs and light switches
does code require that a lightswitch be on the same side of a doorway as the doorknob?
i realize it is more ergonomic/functional to have it that way but is it a requirement?
thanks.
gregdonovan is offline   Reply With Quote
Old 06-19-2009, 03:51 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by gregdonovan View Post
does code require that a lightswitch be on the same side of a doorway as the doorknob?....
All I know is that they are required for every habitable room and you cannot put them on the floor or the ceiling.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-19-2009, 04:51 PM   #3
Electrician
Rewards Points: 794
But how fun it would be to wire up someones house and put all the switches in the ceiling, the look on there face would be priceless.
darren is offline   Reply With Quote
Old 06-19-2009, 05:09 PM   #4
I've always had the bathroom lights switch on the outside
Bedrooms & other rooms on the inside
Walk-in closet on the outside
What if the person did not have arms & wanted floor switches?
Old 06-19-2009, 05:12 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
Guess they wouldn't be in the market for a 'clapper' either?
Man of many hats
wrangler is offline   Reply With Quote
Old 06-19-2009, 05:18 PM   #6
A stamper maybe?
Old 06-19-2009, 05:19 PM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
That would work... as long as there are no little ones around that are in the habit of throwing fits.
Man of many hats
Old 06-19-2009, 11:24 PM   #8
well crap, there goes that plan...
thanks.
Old 06-20-2009, 04:55 AM   #9
Electrical Contractor
kbsparky's Avatar
Nope. While this is a convenience issue, it is not a Code violation to locate a wall switch behind a door.
Old 06-20-2009, 07:41 AM   #10
Rewards Points: 338
wrangler, "That would work... as long as there are no little ones around that are in the habit of throwing fits." There's a similar reason for not instaling the "clapper" in Honeymoon suites....
petey_c is offline   Reply With Quote
Old 06-20-2009, 07:56 AM   #11
Newbie Bill
Rewards Points: 522
How do you keep everyone from turning the lights off on you and leaving you sitting in the dark? In the one place I lived with the switches like that it was regular practice to turn the light off as you walked by.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-20-2009, 08:25 AM   #12
zpm
yeah, right
What's your reasoning for that? It just seems "wrong".
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 06-20-2009, 09:14 AM   #13
Remodeler
adpanko's Avatar
Rewards Points: 150
Switch not required to be on knob side
We recently had a new front door installed, and the place ordered and installed the opposite swing from what it was supposed to be. So after the install, the door knob was on the right side of the door, instead of the left, like it was prior. And the light switches were on the left side too. So I did some investigating and found that it wasn't a violation of NEC, which doesn't stipulate what side the switches have to be on. But it the door swing direction was more an issue of natural flow into/out of the house. where the switches were, where the mailbox was, etc. And in case you're wondering, the door company replaced the door at no cost to get it back to the proper swing direction.
adpanko is offline   Reply With Quote
Old 06-20-2009, 10:03 AM   #14
Crazy, but lovable
flyboy2610's Avatar
I was wondering the same thing.
Could be kind of funny, though!
flyboy2610 is offline   Reply With Quote
Old 06-20-2009, 12:25 PM   #15
Outside lighted switch controls one overhead light
Going towartds the bathroom at night it allows you to easily turn on the light
There are 2 more switches by the toilet, one controls the overhead fan
The other controls the 3 light vanity
In addition there are 2 LED lights in the bathroom
At nite I don't even use the light
2nd floor bathroom has basically the same setup
