Doorbell Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 09:42 AM   #1
Doorbell Wiring
I have two doorbell chimes with a front and rear button. The existing transformer has been replaced but now I can't get a two chime audible noise when the rear button is depressed. The chimes should have one tone for the front door and two tones for the rear door. Any ideas on what the problem may be?
Jay Byrd is offline   Reply With Quote
Old 04-18-2011, 09:59 AM   #2
Rewards Points: 1,512
Does the plunger for the rear door chime move at all when you press the button?
It is possible that the voltage of the new transformer is too low to activate the chimes. There may be an adjustment (connecting to a different tab) for the transformer
Be careful when using illuminated pushbuttons. Too high a voltage will burn them out. If the voltage needed to operate the chime is more than the lights use, you may be able to use a lower voltage setting by stringing thicker wires over part or all of the doorbell circuits.
Note: If you calculate voltage drop for the chime and jack up the voltage to compensate, illuminated pushbuttons will still burn out. This is because fewer volts are dropped within the wires when only the lights are on.
Old 04-18-2011, 11:54 AM   #3
joed's Avatar
Rewards Points: 12,852
Did you check the button. Maybe it is stuck. Maybe that is what burnt out the first transformer.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Doorbell wiring problem schulte24 Electrical 9 08-28-2008 08:40 PM
Wiring a Doorbell jelly Electrical 3 05-30-2008 11:48 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
