Old 04-03-2012, 01:46 PM   #1
Doorbell wire in brick wall is too short
Recently we moved into a home and the doorbell is missing. There is a small hole in the brick wall with two wires inside. I've tried to pull the wires out of the hole in order to extend them enough to connect to a new doorbell unsuccessfully. Is there some easy way that I could strip the ends of these two wires and connect a similar gauge wire to them? I do not want to install a wireless doorbell.
Thanks for your help. I'm going to try and post a picture as well. The brick hole diameter is about 3/4".
benmiller22 is offline   Reply With Quote
Old 04-03-2012, 02:12 PM   #2
It's usually not this simple, but, just for kicks, I would check the basement and/or attic, to see if you can find this wire; if so, maybe you can pick up some slack, then pull it through. Or, if it's taut at that point, maybe you could make your splice up or down there, and pull it through then. Again, seldom quite that simple, but you get lucky every once in a while.
Old 04-03-2012, 02:20 PM   #3
You might be able to stick the tip of a soldering gun in to melt off some of the insulation, then stick in rolled up sandpaper to clean off the ends, then stick the soldering tip in again and attach pigtails (short extensions) to those wire ends. Slip heat shrink tubing over for insulation; you might be able to heat up the tubing with the soldering tip but do not use a match or flame to actually make it shrink.
Make a spiral in the end of the pigtail to slip over the wire end in the wall, instead of trying to twist the pigtail end and the wire end together first.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
The Following 3 Users Say Thank You to AllanJ For This Useful Post:
Billy_Bob (04-03-2012), mpoulton (04-03-2012), zappa (04-03-2012)
Old 04-03-2012, 03:42 PM   #4
A lot of times the doorbell wire runs to the button location behind the trim on the inside. You might check if thats the case. If so, you could splice it together in there and extend the wire out to the button location
danpik is offline   Reply With Quote
Old 04-03-2012, 05:59 PM   #5
Licensed Electrician
k_buz's Avatar
Worst case scenario put the new button over the existing hole (top of the button lined up with the top of the existing hole) trace the new button on the wall, then gently chip out a bigger hole...working your way down. You might be able to get enough wire out to either connect to the button, or splice on a little wire. I know you will loose surface to mount the new button, but a little caulk should hold it there just fine.
k_buz is online now   Reply With Quote
Old 04-03-2012, 07:39 PM   #6
STAFF
BigJim's Avatar
Or if all else fails buy a battery powered remote doorbell.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 04-03-2012, 10:33 PM   #7
Msradell's Avatar
From the OP "I do not want to install a wireless doorbell."
Msradell is offline   Reply With Quote
Old 04-03-2012, 10:40 PM   #8
Learning Things Every Day
Jay 78's Avatar
I went wireless. I was extremely skeptical, but it has turned out to be totally reliable.
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-03-2012, 10:50 PM   #9
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
try and strip the wire with a couple pairs of needle nose pliers and crimp splices on with needle nose pliers.
If you have a soldering iron this can be fixed easily. Strip insulation from a larger size wire slide some on both new wires solder the wires together 3/4" is plenty of room slide the insulation over the wires and tape it up.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Tags
doorbell, electrical, wire
Brick Wall Fireplace Questions mjoe Remodeling 3 12-03-2012 08:40 AM
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
covering interior wall with full size brick SydneyJames Remodeling 5 11-11-2010 05:54 PM
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 09:52 AM
