Doorbell Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 06:17 PM   #1
gid
Question
Doorbell Voltage
Ok, so our 3 year old pos doorbell button already rotted, so I went to replace it with one from Lowes. The catch is the Lowes button says max 16 volts (I think all said this), but I tested the line and it's 21 volts. Is it safe to use, are there buttons that can handle more volts? I've gotten burned before using the wrong voltage/wattage things, so I don't want to just try it and create an electric hazzard. All the buttons online that I could find don't state the max wattage. What gives? I tested the voltage on the button wires themselves and coming off of the transformer.
gid is offline   Reply With Quote
Old 03-19-2011, 06:54 PM   #2
Mad Scientist
It's probably fine. I suspect that if you check the voltage at the transformer while the button is pushed to ring the bell, that the voltage will be lower.
Many power supplies and small transformers have a higher voltage with no load on them.
McSteve is offline   Reply With Quote
Old 03-20-2011, 09:54 PM   #3
gid
Thanks, it works fine so far. I'll be sure to let you know if anything bursts into flames.
Tags
doorbell button voltage
Old Doorbell Voltage karatehero Electrical 19 10-21-2010 09:36 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
16v Doorbell voltage safety pcampbell Electrical 5 06-06-2008 12:38 PM
