Doorbell Troubleshooting? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 09:35 PM   #1
aquaholic's Avatar
Rewards Points: 29
I recently purchased a condo which has a non functional doorbell. There are 4 wires at the doorbell and 2 wires on the button. But there doesn't seem to be any power anywhere and I can't find a transformer anywhere!? Any ideas?
aquaholic is offline   Reply With Quote
Old 02-28-2013, 09:38 PM   #2
Rewards Points: 12,878
Could be almost anywhere.
I've found them under the house, in closits, in the garage.
Old 02-28-2013, 09:47 PM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
Uh, Looking at the bottom of the doorbell, looks like it needs 4 D size batteries...
theatretch85 is offline   Reply With Quote
Old 02-28-2013, 10:01 PM   #4
aquaholic's Avatar
Rewards Points: 29
Ok that's what I thought but guy at Home Depot said they were just referring to the voltage and polarity of the wires?? I also couldn't find anything similar at any hardware store...
Old 02-28-2013, 10:54 PM   #5
if you had 4 wires then 2 should have been from the transformer and the other 2 to the button. it looks like battery locations but there are no metal contact strips for them. sometimes the transformer is attached to or near the electrical panel. evidently the guy at home depot didn't know that doorbells usually run on 24 volts and not 6 volts. there is also the possibility that it was forgotten and you don't have one.
Old 03-01-2013, 12:21 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Most resdentail doorbell units I know on standard format useally run on 16 volts not on 24 volts ( that is very rare )
Merci,
Marc
Old 03-01-2013, 05:56 AM   #7
I must say, try to use another doorbell, because when you are in condo, its hard to hear voices from outside. Maybe you should try to repair your doorbell or you just change it, or better yet, call for help to the experts for they know what's best.
scottharrison is offline   Reply With Quote
Old 03-01-2013, 07:25 AM   #8
Rewards Points: 1,418
Does this doorbell rely on its own batteries and has no connection to a transformer and just two wires going down to the button?
Doorbells in an apartment complex are likely to be powered from a common area circuit so the transformer may be down where the master breaker for the building is.
On some doorbell circuits it is not possible to measure voltage unless you put one meter probe on one of the button wires and the other meter probe on one of the chime (bell unit) location wires. Hint: You'll need a long single conductor wire between 14 and 20 gauge that you stretch up the stairs and across the floor to where you are working.
Which two wires at the chime show continuity when you short together the two wires at the button and show no continuity when you separate the two wires at the button? (Do not try to measure continuity between two wires that you measured non-zero voltage between.) Connect just those two to a battery powered bell unit.
Old 03-01-2013, 08:38 AM   #9
joed's Avatar
Rewards Points: 11,608
It appears to use batteries. That is DC power. A transformer is AC power so I doubt it has a transformer.
You could test the wires by putting an ohmmeter across them and having someone push the button at each door. That will confirm where the wires go.
Is there brand and model number on the unit anywhere?
Old 03-01-2013, 01:38 PM   #10
Oso954's Avatar
Rewards Points: 444
They do make hybrid doorbells that will work as wired AC units or battery powered DC units.
The 4 wires indicate that this was a wired service.
I'd talk to the neighbors (or the maintenance man, if your condo has one) and see if they know where their doorbell transformer is. Yours is probably in a similar location.
Oso954 is online now   Reply With Quote
Old 03-01-2013, 11:17 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,098
Some door bells do work off 24v,
But not all !
the unit shows 4 x D size cells,
so I would try 6v dc first.
If it works ok just use a wall wart.
dmxtothemax is offline   Reply With Quote
Locating Doorbell Transformer RodC Electrical 13 11-13-2012 07:00 PM
Converting a wired to a wireless doorbell ohman Electrical 12 10-22-2012 11:20 AM
Problem with wire to doorbell button. darsunt Electrical 7 03-04-2012 09:40 AM
Troubleshooting this doorbell darsunt Electrical 14 09-20-2011 01:02 PM
Doorbell Question captainron19 Electrical 21 03-05-2010 05:40 PM
