Doorbell Transformer Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 08:24 PM   #1
I've got a bit of a problem, my doorbell quit working and I have decided that the transformer is bad. That is not my problem. Finding the dead transformer is the problem. When I had the house built in 1980 the electrician located the transformer in the attic and it worked flawlessly for over 30 yrs. The problem is that over the years the cellulose insulation settled and I had more blown in, a couple of times, and now the transformer is buried under the insulation. I thought I knew where it is located but its not where I thought it was. I have tried feeling around with a stick but no luck. Anybody got an idea how to locate it? I thought about a metal detector but I do not have one or know anybody that does. I tried to find the wires from the buttons but they do not go all the way up to the attic at the doors. I tried following wires that I found in the insulation but none of them led to the transformer. Anybody got anything?
oldfatnbroke is offline   Reply With Quote
Old 01-11-2012, 08:28 PM   #2
Rewards Points: 6,652
Metal Detector and a scuba mask.
Old 01-11-2012, 08:47 PM   #3
Ironlight's Avatar
Ahhh...doorbell diving!
Ironlight is offline   Reply With Quote
Old 01-11-2012, 08:51 PM   #4
Rewards Points: 12,808
I got tired of those things years ago and now install wireless ones.
No more loose, corroded connections, no transformers, can add a back door one that has a differant chime.
Old 01-11-2012, 09:15 PM   #5
Rewards Points: 582
hope you had better luck than most others door bell rings in the middle of night ????alot of false rings....must be on the same frequency as others.....find the hard wire replace transformer
Old 01-11-2012, 09:51 PM   #6
Missouri Bound's Avatar
First...verify that it is dead with a meter at the pushbutton. Then you can use a tone generator and a tracer to locate where the wires end.....like the phone company uses.
The Following User Says Thank You to Missouri Bound For This Useful Post:
ben's plumbing (01-11-2012)
Old 01-11-2012, 10:29 PM   #7
joed's Avatar
Rewards Points: 11,548
I would look above all the light fixtures. They probably installed on an existing box rather than install a box just for the transformer.
Old 01-11-2012, 10:36 PM   #8
Honey, the batteries are out on the doorbell system again!
Jdizzle is offline   Reply With Quote
Old 01-11-2012, 10:39 PM   #9
Rewards Points: 582
would someone get the door ..ok mom hey there no one here...what theres no one here.....
Old 01-11-2012, 10:43 PM   #10
Find the receiver and look around. They are usually found in closets.(older homes)
doorbell transformer question Buzzman Electrical 3 06-17-2011 08:49 AM
wiring problem: 120V to 12V Halogen Ceiling Lights with transformer Uncledan Electrical 3 01-20-2010 06:32 PM
Doorbell wiring problem schulte24 Electrical 9 08-28-2008 09:40 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
