11-29-2009, 04:30 PM
#1
Doorbell Transformer
My doorbell transformer primary hot wire is stuffed into the closest breaker along with a #12 black wire. The doorbell wire is about a #18 tinned copper. The doorbell wire is loose with the breaker terminal screw torqued against the #12 black wire.
11-29-2009, 06:43 PM
#2
It was a dark and stormy
And. . .?
11-29-2009, 07:33 PM
#3
Looking for a solution. Thanks!
11-29-2009, 08:09 PM
#4
Lightly sand both wires and wrap the smaller wire around the larger wire
http://www.web3d.org/x3d/specificati...ages/helix.gif
and solder the joint so the screw puts pressure on both?
11-29-2009, 08:39 PM
#5
Do you have a question?
Or is there a problem?
Etc.
11-29-2009, 08:49 PM
#6
Licensed electrician
Just pigtail a short length of #12 to the lead and cap with a wirenut. Attach the other end under the breaker screw.
11-29-2009, 08:52 PM
#7
Originally Posted by Yoyizit
And. . .?
So is someone to assume that you believe a loose connection is proper and would not lead to problems?
Are you aware that unless breakers are listed for use with multiple conductors that this is a violation? Even breakers that can accept 2 conductors require the conductors to be the same size and material.
11-30-2009, 03:09 PM
#8
In this case, the likelihood that this particular loose connection, soldered or unsoldered, usually carrying only the magnetizing current of a bell 'frmr, would lead to a fatality is probably less than 1 in 100,000, per year. Driving a car, per year, is 10x as dangerous. Smoking, 100x.
Fear, uncertainty and doubt sells a lot of stuff.
Some of what the NEC tells you is reasonable and prudent. As for
the bucks you pay for the equipment
vs.
the extra safety your dollars buy. . .? "I believe" that's a different story.
Have you seen how many industry reps are on the code panels? Did you ever hear of
http://en.wikipedia.org/wiki/Regulatory_capture
11-30-2009, 03:15 PM
#9
Also would like to add that Solder shouldn't ever be in the equation there.
With very few exceptions there is no install method that would require/permit soldering wires and still be NEC compliant...
Reason: (I can't spell)
11-30-2009, 06:43 PM
#10
vs.
I don't know where you came up with those "statistics" nor do I care. I feel it is irresponsible to give misleading and potentially dangerous advice.
FWIW, 1 out of 100,00 equates to more deaths that I would like to think about given that the population in this country is over 300 million. Using fuzzy math that sounds like 3000 people per year could die from following your advice. Do you find that acceptable? I would not want that on me.
I am well aware that the code making panels have industry reps on them. They also have contractors and other professionals on them. While I might not agree with some of the trends that seem to becoming more predominant like the design issues, overall I feel that the true purpose of providing a safe system is still foremost in them minds of the CMPs.
11-30-2009, 06:45 PM
#11
Xtreme DIY'r
So you are saying that soldering wires is not allowed by the NEC ?
Could you please quote the code section for that ?
I'd never solder the connections & then attach to the breaker
I would solder it to a pigtail, cap it & then attach the pigtail to the breaker
11-30-2009, 07:00 PM
#12
1
2
1 It's fatal house fires per year in the US from all causes so it is a max.
How many fatal house fires per year, or per decade, would be caused by twisting these wires together, or just leaving them as they were?
It's not "on" me. It's on the OP. The OP ultimately makes, or should be making, his/her own risk/benefit tradeoffs.
That's one problem with the NEC; it decides for us.
Of course, as illustrated with this recent mammogram screening dustup, the public may react with confusion or rage if you give them data and let them decide.
2 Good, and optimistic, answer. What bothers me is that there is no disincentive to not pile one costly [to the consumer] safety measure on top of another. When is it safe enough? The Stigler guy who thought up the idea of regulatory capture believed it was an inevitable outcome.
11-30-2009, 07:04 PM
#13
Sure, but how much of an informed decision can be made when the data used to form that decision is flawed?
Maybe the fact the the NEC makes those decisions for us is a saving grace. Otherwise there would be more fatalities.
11-30-2009, 07:10 PM
#14
The defense rests.
11-30-2009, 07:19 PM
#15
Xtreme DIY'r
This is the method to use, not solder
While solder may work....wires under a breaker or bus in the panel must be the same gauge
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
