Doorbell Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 06:59 PM   #1
Rewards Points: 640
Doorbell transformer
I want to put a hardwired doorbell into our house, right now its wireless and (a piece of junk).... most of the transformers are 30 to 40 watt.. which for chimes that is pretty much needed... but my question is, does the transformer constantly used that many watts? or is that just momentary usaged when the chimes are running? Thanks!
BlueBSH is offline   Reply With Quote
Old 11-28-2009, 07:15 PM   #2
Thumbs up
It means that the Transformer has the capacity for using equipment up to the Amperage or wattage rating. The Transformer itself is using a negligible amount of power when the induced secondary voltage is picked up due to the collapsing field in the primary. (Now, I know this was too complicated and not necessary for practical usage. But some Theory is worth reviewing, sometimes.)
spark plug is offline   Reply With Quote
Old 11-28-2009, 07:19 PM   #3
Rewards Points: 640
That's how I thought it worked, thanks for confirming it for me!
Old 11-28-2009, 07:43 PM   #4
An energy saving design of wired doorbells is...
To use a regular 120 volt type electrical box at the front door, a blank cover plate, and a momentary push button switch rated for at least 120 volts. Then drill a hole for the switch in the center of the blank cover plate. And install using regular romex wire like you would a 120 volt light switch.
Then you would need to use an old fashioned "ding dong" door bell, bell, or buzzer. (Electronic doorbells need "always on" electricity to work right.)
Wire the momentary push button switch to power on the 120 volt side of the doorbell transformer. Wire the secondary side of the transformer directly to the doorbell.
Push the button and it powers on the transformer and then the doorbell. Release the button and it uses no electricity.
If the button is in a wet area, the power for this circuit would need to come from a GFCI protected circuit.
I used a brass blank plate for my doorbell and it looks like this...
(Metal plate grounded)
Billy_Bob is offline   Reply With Quote
Old 11-28-2009, 08:13 PM   #5
"A transformer is designed so that the magnetizing current is a small fraction of the normal load current, usually only a few per cent."
transformer questions Steelhead Electrical 8 10-25-2009 08:39 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
