Doorbell Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 12:04 PM   #1
Mlwhite's Avatar
Rewards Points: 29
Doorbell transformer
Recently bought a house. The doorbell quite chiming. Electrician (home warranty) said the transformer wasn't big enough for the chime in both the upstairs and downstairs. Basement is finished. Is there an easy way to find out where the transformer is without cutting a thousand holes in the ceiling?
Thanks,
Michelle
Mlwhite is offline   Reply With Quote
Old 01-02-2012, 12:09 PM   #2
Rewards Points: 6,652
The handyman is a idiot. As for its location, could be inside the breaker panel, on the side, up in the attic, in the garage, in the ceiling of the basement, inside of a junction box with a blank on it, behind the chime hanging on the wall. Time for you to figure out which circuit powers it, and use a Fox & Hound to trace the low-voltage wiring from the chime to the location of the transformer.
My guess is that you said that the basement was finished, who knows what mysteries you will find up there, so you may not be ready for that one.
Old 01-02-2012, 12:29 PM   #3
Mlwhite's Avatar
Rewards Points: 29
Not in any visible location ( breaker box, garage, attic). I can't seem to trace the wires, because of it being finished. Everything is on the same circuit so that didn't help.
Old 01-02-2012, 01:05 PM   #4
Rewards Points: 1,452
If the transformer can work either front or back door, it's big enough.
Rarely if ever are both doors buttons pressed at the same time and even so, you will get a confusing sound or just one of the tone sequences.
Sometimes heavier wiring will help. If so, and it is possible and accessible to upgrade just one of hte wires, that will improve things even if the other wire is not upgraded.
If the transformer has selections for different voltages (using taps) do not choose a higher voltage if you use illuminated buttons that call for a lower voltage. You will burn out the buttons.
AllanJ is online now   Reply With Quote
Old 01-02-2012, 01:18 PM   #5
Like I stated before, you will need a Fox & Hound set.
Old 01-02-2012, 02:54 PM   #6
Mlwhite's Avatar
Rewards Points: 29
Okay maybe I'm not being clear. There is a door chime upstairs and also one in the basement. They are tied to the same transformer. Only one button at the front door. I think it was added so when in the basement they could hear the doorbell upstairs. What is a fox and hound and where can I get one?
Old 01-02-2012, 02:58 PM   #7
Ironlight's Avatar
http://www.amazon.com/Triplett-3399-.../dp/B0002EHP8E
Ironlight is offline   Reply With Quote
Old 01-02-2012, 03:47 PM   #8
I would get rid of one of the chimes, and put in a wireless one. The transmitter would connect at the doorbell chime downstairs, and the receiver would be the new chime upstairs.
help, doorbell transformer inside electrical panel, PIC's blackhemi Electrical 10 07-20-2011 01:47 PM
doorbell transformer question Buzzman Electrical 3 06-17-2011 08:49 AM
Do smoke detector and doorbell transformer count as outlets? wj618 Electrical 5 01-28-2011 06:22 PM
Doorbell Transformer fpeikin Electrical 14 11-30-2009 07:19 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
