Doorbell Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 01:31 PM   #16
Rewards Points: 1,192
You are missing the"trans" wire to the chimes assembly.This is the power from the bell xfmr.Most doorbells you buy are 10 volts.
bobelectric is offline   Reply With Quote
Old 03-05-2010, 01:33 PM   #17
Rewards Points: 16
But why would it work fine now when the doorbell button is pressed.?
captainron19 is offline   Reply With Quote
Old 03-05-2010, 02:06 PM   #18
If you aren't tired of this yet,try hooking the common back to the "trans"terminal and see what happens.
Old 03-05-2010, 02:09 PM   #19
Rewards Points: 16
Which one is the common? I have 2 red wires near the chime and 2 white wires that were twisted together.
Also ... is it possible that the wires are on the wrong terminals on the transformer? I noticed the terminals are not marked in any way so we just put the red and white on there.
Old 03-05-2010, 03:31 PM   #20
Tom Struble's Avatar
Rewards Points: 2,002
maybe the bulb in the button went when the transformer did
Tom Struble is offline   Reply With Quote
Old 03-05-2010, 04:13 PM   #21
Master Electrician
Rewards Points: 3,964
Originally Posted by captainron19 View Post
Here is a picture of the current configuration working but the doorbell light is not on any more
Looks to me like one of those two red wires should be connected to the "transformer" screw.
brric is offline   Reply With Quote
Old 03-05-2010, 04:40 PM   #22
touch the whites to the "trans" screw,and if they are ok,nothing buzzing or weird,connect them up and check button and light.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
