Doorbell Operation & Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 04:43 AM   #1
Rewards Points: 20
I am in process of reclaiming some attic space, closing it in to estabish as a closet. I noticed that the doorbell transformer and its power supply is located in attic space, next to an inoperable chimney. The transformer is warm to the touch.
I want to close this space in...but not sure what to do with the transformer and power source. Seems like I should move it inside the room and enclose it in a electrical power box.
Suggestions?
hunt4cleanair is offline   Reply With Quote
Old 05-23-2013, 07:19 AM   #2
Rewards Points: 1,532
The transformer can be moved but if the wires don't reach the new location then you need a box with exposed cover where you spliced on extra lengths of wire.
The transformer itself needs air for cooling. I suggest that if you do enclose it in a box then the box needs to:
1. Be made of metal,
2. Have an exposed cover,
3. Not have wall or ceiling insulation within 4 inches of it,
4. Be large enough so that six transformers of that size will fit inside.
Old 05-23-2013, 12:17 PM   #3
Rewards Points: 20
Sounds like I should leave it as which is in attic space but exposed to the natural soffit/ridge vent circulation. Currently, its behind a wall with an 12" x 12" opening that I want to close in and use the space as interior space storage. Perhaps, leave it and make a trap door with access to the transformer. Would that work better than trying to move it inside?
Old 05-23-2013, 12:26 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
I personally prefer wireless door bells. People are afraid to come to my house, so our door bell rarely gets used. It's been about 5 years with the same batteries....
No wires....and we can put the dinger anywhere we want.
Old 05-23-2013, 12:50 PM   #5
Rewards Points: 744
Originally Posted by ddawg16 View Post
People are afraid to come to my house.
Seattle2k is offline   Reply With Quote
Old 05-23-2013, 01:20 PM   #6
Rewards Points: 20
Unhappy
Not a bad idea. I have a dinger in one place downstairs, the transformer upstairs and a circuit board of sorts in a downstairs utility room! Wires from the outside buttons are routed under the house, up over and probably areas I am still discovering!
Old 05-23-2013, 01:39 PM   #7
JOATMON
ddawg16's Avatar
If you start looking into the wireless stuff, you start finding all sorts of options...for example, it's easier to add additional dingers....and you can tie them into a video monitor system...etc.
fun stuff.....
Locating Doorbell Transformer RodC Electrical 13 11-13-2012 06:00 PM
Doorbell Transformer Problem oldfatnbroke Electrical 9 01-11-2012 09:43 PM
help, doorbell transformer inside electrical panel, PIC's blackhemi Electrical 10 07-20-2011 12:47 PM
doorbell transformer question Buzzman Electrical 3 06-17-2011 07:49 AM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
