Doorbell Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 10:08 PM   #1
Rewards Points: 33
Doorbell issue
I have a typical ding dong doorbell. The button is obviously at my front door, the chime is above my stairs and very unusual. It has 2 wires coming from the back that splits into a red and yellow wire. So there's 2 reds and 2 yellows. The bell has screw connectors that say, front, transformer, and rear. The installer installed one red to the front, another red to the transformer, and twisted the 2 yellows and wired to the rear. I want to rewire this and try to salvage the existing doorbell. Works fine but I want it to be wired right and not all amateury. Someone help me through this rewiring process?
Elton20 is offline   Reply With Quote
Old 12-21-2012, 10:13 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If it works, don't touch it.
The Following User Says Thank You to k_buz For This Useful Post:
NJMarine (12-22-2012)
Old 12-22-2012, 07:20 AM   #3
Rewards Points: 1,506
Does the plunger or clapper for the rear chime sound (the one that does not move when you press the (front) button vibrate or hum if you touch it with your fingers? (Try it both with someone pressing the front button and without.)
If you unhook the two yellow wires from the "rear" terminal but leave them twisted to each other, does the (front) doorbell still work?
Old 12-22-2012, 07:51 AM   #4
Rewards Points: 2,516
Is there a button at another door?
Is the ding-dong not functioning properly?
A picture would probably help.
hammerlane is offline   Reply With Quote
Old 12-23-2012, 12:41 AM   #5
Rewards Points: 33
I don't think there's a rear doorbell. I never found one. I just taped off the yellow wire and kept it disconnected. I've also noticed that it dings but doesn't dong that well. Like it use to.
Tags
doorbell , rewire
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
doorbell transformer question Buzzman Electrical 3 06-17-2011 07:49 AM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
