Doorbell Diode - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 10:52 PM   #16
Buzzing doorbell due to rectifying diode. (Not an LED)
AllanJ,
You are refering to a bicolor LED which has two Light Emitting diodes of opposite polarity.
An LED is a special kind of Diode.
However, all electronic door bells come with a rectifying diode that does not light up.
The discussion thread was not about the light in the button of the doorbell.
The transformers used to lower the voltage going to the door bell are cheaply made, and vary in voltage output. If buzzing occurs when the diode is attached, it usually is caused by the incorrect voltage from the transformer. Ususally located up in the attic, or garage of the house.
angryhippo is offline   Reply With Quote
Doorbell wiring problem schulte24 Electrical 9 08-28-2008 08:40 PM
Installed doorbell - chiming not right proofer Electrical 3 07-08-2008 03:04 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
