Doorbell Diode - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 04:50 PM   #1
Doorbell Diode
Installed new chime unit, new doorbell button on front and regular doorbell on back. When diode is on front doorbell button, it constantly buzzes. I have spent two days on this and I'm a little frustrated. Help
hindelicato is offline   Reply With Quote
Old 02-15-2009, 05:03 PM   #2
the Musigician
DangerMouse's Avatar
When diode is on front doorbell button, it constantly buzzes?
you mean diode as in light? i don't follow....
DM
Old 02-15-2009, 05:07 PM   #3
Try reversing the wires!
Old 02-15-2009, 05:14 PM   #4
I'd say the bell end of your setup is wired incorrectly or you could try reversing the diode polarity.
Seems like when the bell is not pressed the chime is getting halfwave rectified DC from the xformer, hopefully of the proper polarity.
When the button is pressed this input terminal of the chime gets AC and this is the signal to ring for that particular button.
Can you post a schematic of the chime insides?
Old 02-15-2009, 05:15 PM   #5
the Musigician
spent two days and didn't try reversing the wires? what else is there? lol
DM
Old 02-15-2009, 07:05 PM   #6
joed's Avatar
Rewards Points: 12,852
Never heard of diode on door bell? Are you sure it's a diode? what heppens if you leave it off?
What if you leave the button off? If it still buzzes then you could have a pinched/shorted wire.
Old 02-15-2009, 08:05 PM   #7
doorbell diode
http://www.musicaldoorbell.com/howtoexisting.htm
Old 02-15-2009, 10:50 PM   #8
Rewards Points: 502
The only other thing I can think of is to flip the diode over....diodes keep electric going in one direction.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 04-10-2010, 05:55 PM   #9
Reversing the wires may not help
The half wave rectified detection circuit does not care about the diode polarity. At least according to the patent.
I had the same issue, and it turned out to be the transformer.
Although rated at the 16V required by the chime, it was putting out 19.9Volts
New transformer fixed the issue.
angryhippo is offline   Reply With Quote
Old 04-10-2010, 06:32 PM   #10
Rewards Points: 1,512
Does the tone of the continuously sounding chime change when the button is pushed?
The chime unit and the diode button (I assume lighted button) may be incompatible with one another.
The diode is lit by the same current running in the same circuit that operates the chime. In most chimes when the button is not pushed and the diode is lit, the amount of current is not enough to sound the chime.
If the chime unit requires only a few milliamperes through the button circuit then the current that lights the diode may be enough to sound the chime.
In the above example, the transformer with the lesser voltage did not supply enough current to sound the chime when the button was not pushed and the diode was lit.
Or maybe the button was defective (if the diode did not light at all); the button being constantly on.
Flipping the diode over -- By exchanging the wires on the button terminals.
Old 04-10-2010, 06:58 PM   #11
Master Electrician
Rewards Points: 3,864
Diodes do not 'light'.
brric is online now   Reply With Quote
Old 04-10-2010, 07:44 PM   #12
Rewards Points: 1,192
I heard they have a "Light Emitting Diode" that promises to be the new energy saver!
bobelectric is offline   Reply With Quote
Old 04-10-2010, 07:50 PM   #13
Master Electrician
that's an LED not a rectifying diode.
Old 04-10-2010, 08:05 PM   #14
I've also seen them "emit" smoke.
Old 04-10-2010, 08:49 PM   #15
Generally an LED will rectify AC just like any other diode. In typical usage the LED is the only thing (besides a current limiting resistor) in the circuit so it doesn't matter that the current flows only in one direction if you applied AC.
I'm told that there are LED's that light up one color when you apply DC one way and they light up a different color when you reverse the polarity. (And a blend of the two colors if you apply AC.) This does violate the definition of "diode".
>>> emit smoke
Too high a transformer voltage will burn out a doorbell button light of any kind. A common reason for increasing the voltage is too thin wires and/or too long a distance from transformer to button to chime.
Doorbell wiring problem schulte24 Electrical 9 08-28-2008 08:40 PM
Installed doorbell - chiming not right proofer Electrical 3 07-08-2008 03:04 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
