Doorbell Connection Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 09:09 PM   #1
Doorbell connection question
I am trying to replace a doorbell chime box in an existing home with a front and back door bell switch. someone removed the old one without labeling the wires.
There are 2 whites and 2 reds at the chime box. It it touch the two whites together i get a little spark. If I touch any other combination of wires I see nothing. if i touch one white wire to the transforer connection point on chime and the other to front it will chime. Of course the doorbell switch is not pressed in so this is not the correct connection. I would greatly appreciate advice on which wire to hook where.
PS: I checked both doorbell switches and each has a red and white wire attached.
Dan
Dhangebr is offline   Reply With Quote
Old 01-07-2013, 01:42 AM   #2
Rewards Points: 616
I have fixed zero doorbells ....sorry
carmon is offline   Reply With Quote
Old 01-07-2013, 01:58 AM   #3
Rewards Points: 13,300
http://www.bing.com/images/search?q=...0B39C6&first=1
Old 01-07-2013, 08:07 AM   #4
DIY staff
Rewards Points: 7,174
You should have 6 wires----not 4----2 from the transformer---2 for each door----
2 transformer wires to the power terminals on the chime---
remaining wires to the front door/ back door terminals
Old 01-07-2013, 09:40 AM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Have you checked at the chime and transformer what is connected there to see if they are all connected from both switches. Do you have a multimeter? Pictures of the connections at both buttons transformer and chime would be helpful.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Locating Doorbell Transformer RodC Electrical 13 11-13-2012 07:00 PM
Converting a wired to a wireless doorbell ohman Electrical 12 10-22-2012 11:20 AM
doorbell transformer question Buzzman Electrical 3 06-17-2011 08:49 AM
Noobish Duct Connection Question jonathan03 HVAC 4 12-30-2008 08:52 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
