Doorbell Button Wires So Small? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 10:44 AM   #1
Rewards Points: 682
Doorbell button wires so small?
A fellow from the hardware store sold these wires for the doorbell circuit between the button switch and the transformer. It is a red and white pair of wires, the tiniest wires I've ever used. They look much smaller than the wires of older doorbell buttons that I've repaired.
I want to double check with you guys, are these wires right?
darsunt is offline   Reply With Quote
Old 02-24-2012, 10:52 AM   #2
Rewards Points: 3,256
They must be pretty darn small cuz I can't even see them.
What gauge are they?
zappa is offline   Reply With Quote
Old 02-24-2012, 11:05 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
You know Zap...micro wires
Kyle
Old 02-24-2012, 12:30 PM   #4
#22 AWG is customary but for short stretches you can use #30. 50' of #22 = 6' of #30, ohm wise.
Old 02-24-2012, 12:38 PM   #5
liscenced electrician
Rewards Points: 538
They sound about right. Make sure you run it in a way it won't be damaged
jimmy21 is offline   Reply With Quote
Old 02-24-2012, 11:07 PM   #6
Rewards Points: 682
Thanks for your comments. I'm going to look at those gauges at the hardware store and familiarize myself with them, to see what gauge this wire I bought is. You have me thinking it is okay even though it is so small.
Anyways the last doorbell button wires I looked at had multiple tiny copper wires twisted together, you know what I am talking about. This wire looks like just one of those tiny copper wires.
Old 02-25-2012, 12:21 AM   #7
Rewards Points: 14,010
I've never seen braded wires use in door bells.
Two tiny solid wires is the norm. It's Low voltage and will work fine.
I need to trace my doorbell wires down into my basement jkeuning Electrical 3 02-17-2012 06:14 PM
Bringing small wires out of a metal box dave11 Electrical 14 05-30-2010 01:32 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
