Doorbell Button Hot To Touch. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 11:19 AM   #1
valcarmo72's Avatar
Doorbell button hot to touch.
I have lighted doorbell button that is hot to the touch. Any reasons why? It is a new line and a new transformer. Any help is appreciated. Also is it a fire hazard?....
valcarmo72 is offline   Reply With Quote
Old 06-03-2013, 11:41 AM   #2
Bill Kearney
Rewards Points: 1,174
Depends on how hot. Most neon lit units will get warm but I wouldn't call it hot. If the plastic on the button is discoloring then, yeah, that'd be too hot.
Are you sure you've got the right voltage transformer being used with it?
wkearney99 is offline   Reply With Quote
Old 06-03-2013, 12:00 PM   #3
valcarmo72's Avatar
Not sure. Electrician put it in. I called him and he said its fine. Not sure why. I'm gonna go to th transformer today and check it. I have a feeling its too high. It's not neon. It has a small tiny regular bulb in it. Will it tell me on the transformer what voltage it is?...
Old 06-03-2013, 12:02 PM   #4
valcarmo72's Avatar
Here is a pic of the type of the doorbell button..
Old 06-03-2013, 01:04 PM   #5
Bill Kearney
From what I recall some transformers can deliver 10v, 16v and 24v. What's your bell unit marked as requiring? The chiming part, not the button. It'd be on the label. I suppose it's possible if your doorbell required 24v but the button required 10v then you'd possibly have a problem. As I recall lighted buttons shouldn't be more than 16v. You could check this yourself by looking at the transfomer and noting where the wires are connected.
Old 06-03-2013, 02:36 PM   #6
valcarmo72's Avatar
Ok...here is the verdict. Chime box calls for 16v transformer and that's what I have. Button is 104 degrees. And the brick moulding around the door is 98 degrees. I figure the light would give it an extra boost in temp so I think I'm good.
Converting a wired to a wireless doorbell ohman Electrical 12 10-22-2012 10:20 AM
One Doorbell Button to 4 Doorbells/Chimes 1BadBoy Electrical 13 05-22-2012 09:14 AM
Problem with wire to doorbell button. darsunt Electrical 7 03-04-2012 08:40 AM
Replacing a doorbell button GeoInMo Electrical 8 09-14-2011 05:10 AM
Question about 2 family doorbell button rns6799 Electrical 1 09-26-2010 07:47 AM
