Doorbell - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 04:24 PM   #1
Doorbell
Is it normal for a doorbell chime to be hooked up to main without a circuit breaker. I've tried every breaker and my voltage tester beeps no matter what.
djgrant is offline   Reply With Quote
Old 06-11-2011, 05:18 PM   #2
Learning by Doing
Leah Frances's Avatar
Doorbells usually have a transformer. A non-contact voltage tester easily pick up phantom voltage. Kill the main if you are really worried. I'd look for the transformer and trace it back to find the right breaker.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-11-2011, 05:43 PM   #3
Thanks, I have found the transformer. It is stuck to the side of an octagonal junction box nearby. I see the wires coming out of the load side that must go to the chime.
My new chime isn't quite working. It's a two note chime, and it makes the second note but while it is trying to make the first note it just buzzes quietly a bit. It says it needs 16 VAC but my transformer is measuring 12 VAC with my multimeter. Is that my problem?
Old 06-11-2011, 05:50 PM   #4
Electrician
Rewards Points: 778
Yes that would be your problem, you need an transformer with an output of 16V.
darren is offline   Reply With Quote
Old 06-14-2011, 09:51 PM   #5
i have douplex i need to installe door bell,chime for the basment and release the electric latch from inside i need wiriing plan pls
jena is offline   Reply With Quote
Old 06-14-2011, 10:26 PM   #6
Question
Originally Posted by jena View Post
i have douplex i need to installe door bell and chime for the basment and release the electric latch from inside the basment i need wiriing plan pls
i allready have bell and chime and release the electric latch for another two appartment
Old 06-15-2011, 07:11 AM   #7
Rewards Points: 1,446
Do not install illuminated doorbell buttons or electronic chimes with a voltage rating less than what your transformer is delivering.
Mechanical chimes (with glockenspiel bars, hollow tubes, bells, etc.) can take a little overvoltage. Overvoltage may be needed to make the chime work if the wires are too thin or the distance to the door is too great. But an illuminated doorbell will still burn out if the voltage supplied is too great.
Doorbell Diode hindelicato Electrical 15 10-30-2010 11:52 PM
Doorbell Question captainron19 Electrical 21 03-05-2010 05:40 PM
Doorbell Transformer fpeikin Electrical 14 11-30-2009 07:19 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 01:53 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 11:12 PM
