-   -   Doorbell (http://www.diychatroom.com/f18/doorbell-107373/)
djgrant 06-11-2011 03:24 PM
Doorbell
Is it normal for a doorbell chime to be hooked up to main without a circuit breaker. I've tried every breaker and my voltage tester beeps no matter what.
Leah Frances 06-11-2011 04:18 PM
Doorbells usually have a transformer. A non-contact voltage tester easily pick up phantom voltage. Kill the main if you are really worried. I'd look for the transformer and trace it back to find the right breaker.
djgrant 06-11-2011 04:43 PM
Thanks, I have found the transformer. It is stuck to the side of an octagonal junction box nearby. I see the wires coming out of the load side that must go to the chime.
My new chime isn't quite working. It's a two note chime, and it makes the second note but while it is trying to make the first note it just buzzes quietly a bit. It says it needs 16 VAC but my transformer is measuring 12 VAC with my multimeter. Is that my problem?
darren 06-11-2011 04:50 PM
Yes that would be your problem, you need an transformer with an output of 16V.
jena 06-14-2011 08:51 PM
i have douplex i need to installe door bell,chime for the basment and release the electric latch from inside i need wiriing plan pls
jena 06-14-2011 09:26 PM
Originally Posted by jena (Post 667493)
:)i have douplex i need to installe door bell and chime for the basment and release the electric latch from inside the basment i need wiriing plan pls
i allready have bell and chime and release the electric latch for another two appartment
AllanJ 06-15-2011 06:11 AM
Do not install illuminated doorbell buttons or electronic chimes with a voltage rating less than what your transformer is delivering.
Mechanical chimes (with glockenspiel bars, hollow tubes, bells, etc.) can take a little overvoltage. Overvoltage may be needed to make the chime work if the wires are too thin or the distance to the door is too great. But an illuminated doorbell will still burn out if the voltage supplied is too great.
