Old 12-25-2008, 07:01 PM   #1
Door not closing properly
Hi Folks,
Need your advice/help. My alarm system shows that my front door isn't closed properly. However, it's closed properly and I'm able to lock it. The circuit on top of the door and frame doesn't come completly in one line. So if I push the door slightly, both magnet come into one line and at that point the alarm system shows that the doors are closed properly. It's a new house and for some reason the home inspector didn't find it!
Can I do something on my own or do I have to seek professional help!!
Thanks,
John
kirridam is offline   Reply With Quote
Old 12-25-2008, 07:05 PM   #2
My License Ain't 4 Sale..
Originally Posted by kirridam View Post
Hi Folks,
Thanks,
John
Um... realign the magnet, maybe?
Old 12-25-2008, 07:25 PM   #3
how do I do that?
Old 12-25-2008, 07:38 PM   #4
how do I do that?
Don't know. Can't see it. Can you take a pic of what you have and post it here?
Old 12-25-2008, 08:22 PM   #5
how do I do that?
The magnet is not wired in to anything. If is just a magnet. The reed switch is what is wired.
Unscrew the magnet and move it or shim it as necessary.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-25-2008, 08:30 PM   #6
I'll take some pictures. Like you mentioned; to unscrew it..I don't see any screw. It's just two metal pieces placed on top of the door and under the frame.
Old 12-26-2008, 09:46 AM   #7
joed's Avatar
Unscrew the part that is on the frame and put something behind it to space it so it aligns with the magnet.
Old 12-27-2008, 08:55 AM   #8
Eibwen
If all you see is a flush circle on the frame and top of the door then they are probably press in contacts. Proper size hole is drilled and then the contact/magnet is just pushed into place.
If its out of alignement you might be able to carefeully pry out the magnet from the top of the door and relocate it to a new proper sized hole to bring it into alignment with the contact on the frame.
Sammy is offline   Reply With Quote
Old 12-27-2008, 05:26 PM   #9
Yes Sammy, it's a flat metal. B/c of that I can't unscrew it. So you are saying that I pull out the flat metal piece from the door and then drill another hole so that the metal piece which is on the door would align with the one on the frame?
Thanks,
John
Self closing hinge removal azhomeowner Remodeling 5 08-07-2012 02:59 AM
Is my old gas boiler operating properly? 73Electra 225 HVAC 2 12-15-2008 06:25 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 02:39 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
