Door Jamb Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 03:54 PM   #1
Door Jamb Switch
I am looking for a 120 vac door jamb switch that will work with a bi-fold door. The only ones I can find will just work with a regular swinging door. Thanks
jhart is offline   Reply With Quote
Old 04-02-2008, 04:23 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Why won't the plunger style work with a bi-fold?
Old 04-02-2008, 04:26 PM   #3
The way the bi-fold door hinges, it doesnt push straight back on the plunger and it will break the plunger off.
Old 04-02-2008, 06:43 PM   #4
Electrician
Here is what I would do...
This is a remcon closet relay which you can use Normally Closed magnets to turn the light on...
chris75 is offline   Reply With Quote
Old 04-02-2008, 06:55 PM   #5
That is certainly what I would, and usually, do.
He said 120v switch at first, but I should have recommended that one as well.
Hopefully the wire is not run yet.
Old 04-03-2008, 08:16 AM   #6
The wire is already run. The customer changed their mind on the type of door they wanted to use.
Old 04-03-2008, 08:40 AM   #7
I ran into this situation on a new home several years ago. Plungers were already installed and the Homeowner switched to bi-folds. Finish carpenter used a small L bracket on the inside of the bi-fold and made them work pretty slick. You might try playing around with something similar. Wish I could remember more but hope this helps.
Jeff
ElectricianJeff is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
3 way switch help imintrouble Electrical 8 12-13-2007 03:54 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
