In Door Ice Maker Repair - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 02:15 PM   #1
Question
My Whirlpool Model MGR 2220398 - In Door Ice Maker has stopped making ice. The water dispenser is working. (Whirlpool Refrigerator Model ED5SHAXM010.) I checked the optic boards, and they are fine. How can I find and fix the problem?
Anna May is offline   Reply With Quote
Old 12-01-2011, 03:54 PM   #2
First determine if it is cycling and trying to fill the ice maker with water every so often.
If not, get the electrical schematics from the manufacturer and use a multimeter to troubleshoot the problem.
If the water solenoid is activating every so often, then check to be sure water can come out of the opening. Is the output frozen? Or it could be a clogged solenoid. Is there a filter before the solenoid? Clean the lines if that is the problem.
If you don't know how to troubleshoot plumbing or electrical problems, call a repairman.
And before doing that, read the instruction manual for the refrigerator. be sure the ice maker is "on" if there are any switches. And try any troubleshooting suggestions in the manual.
Billy_Bob is offline   Reply With Quote
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
