Door Chime And Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 01:48 PM   #1
Unhappy
door chime and transformer
Because I didn't know what I was doing, I bought a 16V Carlon door chime but found out when it didn't work that I had a 10V transformer. Am I correct that this is the reason that it didn't work? Both the door bell and door button definitely work.
However, the door chime box states "for new installation a 16-volt, 10VA Carlon transformer is required #DH965". What does 10VA mean? I cannot find a 10V door chime anywhere.
Thanks,
Linda
linda moggio is offline   Reply With Quote
Old 02-11-2010, 04:22 PM   #2
Rewards Points: 266
10 VA is just the size of the transformer; how much it can supply. Some people have 2 door chimes in their house and need a larger transformer.
You are correct though, you will need a 16 V transformer. The 10 V one is only for actual doorbells, and buzzers. If it is easy to get to (not buried in the attic) it is quite simple to replace.
junkcollector is offline   Reply With Quote
Old 02-11-2010, 04:36 PM   #3
Newbie Bill
Rewards Points: 520
Mine is atop a light fixture in my unfinished basement.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 02-11-2010, 04:46 PM   #4
Rewards Points: 152
I had the exact same problem! Replaced my existing transformer (mounted on the side of my electrical box) with this:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
and it fixed it right up.
burnt03 is offline   Reply With Quote
Old 02-11-2010, 10:52 PM   #5
Door chime and transformer
Thanks, JunkCollector. I guess my old door chime was compatible with the 10V transformer. Re 10VA, I guess I don't need it because I have only one chime. I'm off to buy a 16V transformer.
Also, DRTBK4ever and Burnt03, my transformer is attached to a light on my basement overhead 2X6. Been there since 1928.
Thanks.
Old 02-11-2010, 10:54 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
va= watts
plummen is offline   Reply With Quote
Old 02-11-2010, 11:14 PM   #7
Oh! Didn't know! Meant to Google VA but didn't get around to it.
Tks
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 02:07 AM
transformer questions Steelhead Electrical 8 10-25-2009 09:39 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 12:10 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
