Door Bell Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 06:51 PM   #1
Door bell wiring
Hello, I have an old door bell in my house and I just recently installed a new back door and wanted to install a button there. I went and checked out the bell it self and it has a back, front and trans screw but only 2 wires not 3. there is a wire coming in that goes to the front and trans and then there is a jumper from front to back. how can I wire in the back door button?
Thanks,
Chad
soggycashew is offline   Reply With Quote
Old 09-01-2009, 07:07 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by soggycashew View Post
..... how can I wire in the back door button?
Chad, Scroll down to "Circuit Diagram":
http://en.wikipedia.org/wiki/Doorbell
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-01-2009, 07:13 PM   #3
300zx's Avatar
Post
Here is a couple more sites on doorbells http://www.doityourself.com/stry/h2installadoorbell http://www.electrical-online.com/doorbellsystems.htm
300zx is offline   Reply With Quote
Old 09-01-2009, 07:14 PM   #4
PaliBob, do I have to purchase a 3 wire? I see how it is wired but it confuses me on what wire I need and where I need it. I see there is a 3 wire from the bell but do I run it near/to the transformer and do all the splitting there? and what would it look like if that's what I did?
Thanks,
Chad
Old 09-01-2009, 07:23 PM   #5
I think I might have figured it out... Thanks everyone for the links.....
Old 09-01-2009, 09:54 PM   #6
Rewards Points: 1,418
If you run the button wires to the bell unit (and do the splitting there) then you only need 2-wire cables throughout. If you run the button wires to the transformer then you will need a 3-wire cable going to the bell.
Old 09-02-2009, 08:11 AM   #7
Thanks for the info...
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
