Door Bell Transformer Install? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2006, 06:44 AM   #1
door bell transformer install?
anyone know how to wire up a doorbell transformer? what need to be done in the panel to the transformer?
THEBIGPUNN is offline   Reply With Quote
Old 07-02-2006, 02:04 PM   #2
you need 110 volts on one side of xfmr, which will be installed through one of the knockouts in your panel. On the other side of the xfmr will be where your 12 volt wire connects, then run that wire any way you want to the doorbell chime.
I've always liked the wireless ones myself, no fuss
Sparky Joe is offline   Reply With Quote
Old 09-09-2010, 08:01 AM   #3
Rewards Points: 1,440
Depending on the mounting provided, you might find it easier to attach the transformer to a junction box rather than directly to the panel. You can install it anywhere that is accessible and where you have 120 volt power although there aren't many places you can install it without its being unsightly. Junction boxes can be attached to panels using nipples as opposed to wired in with a short length of Romex.
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 02:23 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
When to install?? jeepwillies Flooring 5 01-21-2007 02:18 PM
