06-14-2010, 09:24 PM
#1
Wire Chewer
Don't you just hate when that happens?
So I'm running a 20 amp receptacle in my office for the AC, and figured, while I'm fishing wire and such, may as well make it worthwhile, so I run two 12/2 (could not find 12/3) so I can break both tabs and have two separate 20 amp circuits.
So to make it easier to run the wire I measure how much I need and cut two pieces to lenght, then tie wrap them together all neatly. I fish the wire, staple it while I make my way to the panel.
1 foot too short! It will go right in the panel, but won't reach the breaker, neutral or ground bar! I guess I'm going to pigtail inside but I really don't like doing that, it's kinda sloppy.  I *could* rerun a new wire, but I really don't like wasting that much wire. I probably could not remove the staples without damaging it not to mention the work I did routing it properly and all that.
Moral of story, always make your cuts a few feet longer then needed!
06-14-2010, 09:41 PM
#2
Master Electrician
end your wire outside the panel in a jb if it's not a finished wall and run new wire from there to the panel....eliminates the need for the inside the panel joint and all it'll cost you is a jb a few marrettes and 6 feet of new wire.
06-14-2010, 09:45 PM
#3
Wire Chewer
I'm thinking of maybe doing that instead. In fact there is an existing JB near the panel I can probably use, if there's room, or I can replace it with a bigger one. Maybe that's better then pig tailing inside the panel. I don't plan to drywall the ceiling so I don't really have to worry about future proofing it, it will always be accessible.
06-14-2010, 09:48 PM
#4
Licensed Electrical Cont.
I'd do it inside the panel before I added a j-box.
Don't forget the two-pole breaker for this.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
06-14-2010, 11:00 PM
#5
I am installing a sub pannel. I measured the distance to be about 135', so I ordered 150'. I really wish I'd ordered 155'. some how I still came up short. I could get it to go if I run it diagonally across the face of the wall, but figured, thats not really the best place to do a hackjob. to do the splice and to convert to thinner copper wire from the heavy aluminum wire (much easier to work with), I decided to add a 60 amp fused switch box (would have got a 100, but they didn't have one in the store, 60 should be enough for my needs). I figure later on down the road, I might get a real electrician to hook it all up to the main, but for now, just a 60 amp breaker.
06-15-2010, 08:12 AM
#6
Originally Posted by forresth
I am installing a sub pannel. I measured the distance to be about 135', so I ordered 150'. I really wish I'd ordered 155'. some how I still came up short. I could get it to go if I run it diagonally across the face of the wall, but figured, thats not really the best place to do a hackjob. to do the splice and to convert to thinner copper wire from the heavy aluminum wire (much easier to work with), .
Going from aluminum to copper is an excellent excuse to use a junction box and "pigtails" a few feet long to make up for a cable that was too short.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
06-15-2010, 08:49 AM
#7
Just call me Andrew
I assume this is so you can't turn off half the outlet when doing work, forgetting the other half is still live?
Good idea, and it's one I wouldn't have thought of if I were doing something like this.
Andrew
06-15-2010, 09:53 AM
#8
Wire Chewer
Yeah pretty sure that's why. I've actually been caught with that once. I changed a plug in someone's house after turning off the power to it. I only tested the top figuring the bottom would be out too, as I was taking it off I got a shock because the bottom half was live.
06-15-2010, 07:28 PM
#9
Wire Chewer
Ended up just tying the wires together and using a single pole breaker, making the outlet just one circuit. It was way to cramped in my panel to do anything more involved. At least I know I have two separate wires going to that receptacle so when I upgrade my panel I can make it two separate circuits. I don't really have a need for it, I just did it because the need may come in the future, and may as well do the job just once.
When I run network jacks I always run 2x as what I need. If I need one jack, I put two, if I need two, I put 4. If only they practiced that at my workplace... they are always short on network jacks, or power.
06-15-2010, 08:34 PM
#10
You talking to me?
we have a little saying around my area;
you can but it off but you can't cut it on.
something I wouldn't typically do for a customer but around the house I have never had any problems with it;
data wiring only uses 2 pairs out of the 4. You can actually split 1 cat5/6 cable and feed 2 jacks.
06-15-2010, 09:22 PM
#11
Xtreme DIY'r
For normal use Yes, splitting jacks is quite common
Bur for giganet speed you use all 4 pairs of wires
06-15-2010, 11:52 PM
#12
You talking to me?
giganet?
how about gigaBIT?
Do you know anybody with gigabit speeds in their homes?
06-15-2010, 11:57 PM
#13
Just call me Andrew
The only effect gigabit would have would be between networked PC's/Devices in the home. And even then your disk has to be able to handle that type of speed. Maxing out a 100meg line over a standard connection....not going to happen
100 megabits/sec = 12 megabytes a second. I'd love those download speeds!
Andrew
06-16-2010, 12:54 PM
#14
Wire Chewer
giganet?
how about gigaBIT?
I do actually, I have a patch panel even. My only issue is all my patch cables are cat5e so I'm not getting true gigabit speeds. Next order to monoprice I will get a bunch of factory made cat6. (better then making my own)
I don't really NEED that speed, it's just nice to have.
06-16-2010, 01:30 PM
#15
Just call me Andrew
What kind of hard drive do you have?
Andrew
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
