Don't Think I Have Power To The Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 01:50 PM   #1
Question
Don't think I have power to the dryer
Check the 50 amp plug and it seems like no power it getting to the plug. The circuit breaker did not trip either. Any other problems I could be missing?
nsb31875 is offline   Reply With Quote
Old 05-15-2011, 02:17 PM   #2
When u say checked the plug...how did you check? Did you use a volt meter?
heartlessmcfly is offline   Reply With Quote
Old 05-15-2011, 02:55 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
exercise the breaker. Sometimes they trip but the handle does not move.
If using a DMM does not indicate power at recp, then you likely have a bad connection. check all connections(power off)
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-15-2011, 06:16 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,104
Check for power at the load side of the breaker,
Could be a faulty breaker.
If there is power on one side of the breaker, (supply side).
But no power on the load side, then it has tripped,
or it is faulty.
dmxtothemax is offline   Reply With Quote
Whirlpool 29" Dryer has no power nsb318 Appliances 10 05-15-2011 04:25 PM
Making a waterproof/weatherproof enclosures for a network camera & its power hub snowfall Building & Construction 0 05-02-2011 11:14 AM
Wiring a 220V dryer plug on a 110 power panel , in Mexico dtedham Electrical 1 04-14-2011 06:15 PM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
