Don't Know Anything About Electrical Work But Need Help. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 09:00 PM   #16
Originally Posted by damage311 View Post
Speedey, we have been living here for 11 months the house is fairly new and the wiring is all new and I do agree, I should't be doing this myself but I am here to learn not hurt myself. Yoyizit, I have nothing else on that outlet except the A/C and I don't have a meter. How can I tell if it is the unit itself. The first two weeks I had it, everything was running fine.
http://www.wholesalesolar.com/pdf.fo...ower-table.pdf
Without a meter I guess you could plug in a load equivalent to that of the AC in the AC outlet and see if the symptom repeats. Each 100w incand. bulb = 0.83 A. What's written on the nameplate for the AC? It might only pull 4A or so.
You could also Google your make and model along with the exact phrase
"trips breaker"
I assume you mean your panel breaker and not the button on the huge fat plug that ACs now have.
Old 09-04-2009, 09:21 PM   #17
Idiot Emeritus
Rewards Points: 1,492
Does the breaker have any type on pushbutton on it? If so, it is either a GFI, or much more likely, an arc-fault.
Like Petey stated, arc-fault breakers are notorious for nuisance tripping where motors are involved. A/C units have at least two motors.
Rob
micromind is offline   Reply With Quote
Old 09-05-2009, 04:19 AM   #18
Familyman
if it was a cheap a/c, you could be having comp problems already. seen it happen many times. myself included. had one last about a month.
i would check for loose connections from breaker to receptacle.
matt700 is offline   Reply With Quote
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 07:28 AM
How to Fix Electrical Outlets That Don't Work limitdiy Electrical 11 08-08-2009 09:44 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
