Does This Wiring Seem Right? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Barjack
Old 06-24-2016, 10:23 PM   #1
Rewards Points: 410
Does this wiring seem right?
I have a White Rodgers BNP150C and have to usethe 4-wire configuration, but I was under the impression that when switching a 240v circuit that both legs have to be switched.
With this wiring configuration doesn't it still leave one leg unswitched essentially still leaving the circuit/heater energized?
"I kissed a light socket once and woke up in a helicopter"
Killavolt is offline   Reply With Quote
Old 06-24-2016, 11:27 PM   #2
Rewards Points: 744
Re: Does this wiring seem right?
if it's a digital thermostat which itself is always powered, there will be a very small trickle of current flowing through that heater circuit. Not enough to cause the heater to get warm though.
Seattle2k is offline   Reply With Quote
Old 06-25-2016, 06:49 AM   #3
Electrician
Rewards Points: 52
A 240V circuit is just like a 120V circuit. If you interrupt any point in the circuit, current will cease to flow. Certain wires and components of the system will still be energized with a potential voltage to ground though.
Not sure about Canadian codes, but as long as that thermostat is not also the disconnecting means, it should be legal. The disconnecting means breaks all of the energized, or potentially energized conductors to the equipment so that it can be safely inspected, serviced, etc.
Speedy Petey likes this.
Barjack is offline   Reply With Quote
Old 06-25-2016, 08:08 AM   #4
Rewards Points: 410
The main disconnect is mere inches away at the breaker panel.
It had better be code legal, I bought it in Canada
Old 06-25-2016, 07:50 PM   #5
Rewards Points: 36
Seems a little weird to me. I've never seen one like this in Canada. Usually both wires are switched.
cjp2003 is offline   Reply With Quote
Old 06-26-2016, 09:13 AM   #6
Rewards Points: 410
And that's pretty much my thoughts on the matter as well.
Old Home Wiring (UPDATE) with pictures mbrando1994 Electrical 7 01-27-2016 05:59 PM
Old House Wiring Traycam Electrical 14 01-03-2015 09:31 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
