Does This Wiring Diagram Work? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2008, 12:40 PM   #1
Does this wiring diagram work?
Folks,
I'm installing a ceiling fan-light combo in a section of a bedroom where there isn't currently a light fixture. I've installed a fan-rated ceiling box, done a three-wire run through the ceiling to my wall and want to connect into power at a dimmer switch that currently serves a wall light in a different part of the bedroom.
I'm wondering if someone can tell me whether my wiring diagram sounds kosher. Note that the new ceiling fan/light dimmer switch in my diagram was specifically design for a ceiling fan light combo.
First, here's what the existing wiring looks behind my old dimmer switch plate (just fyi, one of the black wires looks a little white but that's just a bit of paint):
And here's the wiring diagram that I've sketched out to add the new ceiling fan/light combo. Thanks!
beezlebub03 is offline   Reply With Quote
Old 05-04-2008, 01:09 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Electrically, the diagram is correct. However, I see at least one potential issue. This appears to be a single gang device box. The diagram shows the new fan device along with the existing dimmer (which can be seen in the picture and is represented in the wiring diagram). How are you going to install the new combo device for the fan in that box along with the dimmer?
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-04-2008, 01:11 PM   #3
Electrician
Rewards Points: 802
Looks like it should work.
darren is offline   Reply With Quote
Old 05-04-2008, 02:29 PM   #4
Jimmy
Jimmy, I thought about dealing with this one of two ways. First, by installing a new double wide electrical box where there is currently a single for the old fixture dimmer switch. Second possibility is there's an unused single electrical box above the dimmer switch box that I could put the ceiling fan switch into (there's some unused cat 5 cabling in there that the previous owners most likely had put in for an intercom system).
Guys, should I also be pig-tailing a ground wire into each switch? The current old dimmer switch doesn't have a ground going into it. I've seen some diagrams that indicate there should be one.
Thanks again, friends!
Old 05-04-2008, 05:43 PM   #5
Rewards Points: 1,274
You should be able to undo the original splice, untwist the grounds and pry the old 1-gang out of the wall. (Let it fall into the wall if you want.) Then replace with a 2-gang old work box. Your wiring diagram is correct. If the existing dimmer did not have a ground pigtail or screw on it, don't worry about it. I recommend for asthetic purposes only, that you replace the old dimmer to match the new dual slide dimmer/ fan speed control.
LawnGuyLandSparky is offline   Reply With Quote
Old 05-04-2008, 11:07 PM   #6
Rewards Points: 566
You could use that box. May look strange however (being higher than the other switch). If you do, you need to remove the cat-5 cable or install a partition to make it legal. Line and low volage cannot share the same JB.
Yes, you should. It could be that the last person removed the ground for some unknown reason. In my municipality, we install everything in steel boxes that are connected together with conduit which serves as the ECG. Since the dimmers do not need an explicit ground connection, I often just twist the wire until it breaks off. You should still be able to see where the ground wire was connected though.
Old 05-04-2008, 11:39 PM   #7
success!
Well, I had to punch a lot of holes in the dry wall, but I got this job done. the ceiling fan and light look great. I spent about $150 for various tools and supplies (that I can use on other projects) versus the $700 or so an electrician wanted to charge me. Thanks for all of your help.
Old 05-04-2008, 11:54 PM   #8
Rewards Points: 566
I always love buying those tools!
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
wiring diagram question screenporch21 Electrical 10 11-30-2008 08:14 PM
Wiring diagram, would this work firemanpato Electrical 10 01-07-2008 04:33 PM
Wiring Diagram Help Designman20 Electrical 3 10-22-2007 05:46 PM
