Does A Welding Generator Need To Be Grounded? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 08:30 PM   #1
Question
Does a welding generator need to be grounded?
Hi,
I am new using a welding generator and I was wondering if someone could tell me if the chassis of the welding generator needs to be grounded? I need to use this in a field where there is no structure grounding. I also do not plan to use the auxiliary outlets, just the welding equipment. The document that came with the welder makes mention to grounding for auxiliary power, thus the confusion
Thanks for your help in advance.
mchinea is offline   Reply With Quote
Old 01-08-2009, 09:20 PM   #2
Rewards Points: 502
In welding mode so long as you have grounded the equipment to the welder, you should be fine.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-08-2009, 10:02 PM   #3
Rewards Points: 2,350
Because the machine is stand-alone, connecting it to the earth will make no difference in the operation or safety of it, either for welding or receptacle power.
Old 01-09-2009, 08:59 AM   #4
Thanks for the reply.
So just to clarify, The document says:
"Grounding the generator when connecting to home, shop, or farm equipment"
Does this implies that if you are delivery power to home or shop or welding farm equipment; That you need to ground to a water pipe or the tractor depending on what your working on?
Also what about
"Grounding the generator to a truck or trailer frame"
Why would you need to ground the generator to the bed of a pickup or trailer frame?
Sorry for the dumb questions, I just want to make sure I dont get zapped in the process...
Thanks!
Old 01-09-2009, 11:56 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It depends.. this is a subject that gets rather complicated. My opinion is it really is black and white if we keep things simple. This particular article is the simplest explanation I've come across. It is also written by very good sources.
http://files.aws.org/technical/facts/FACT-29.PDF
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-09-2009, 12:43 PM   #6
Not to hijack the thread, but the only way for current to flow to the earth through a person from an ungrounded generator would be through capacitive coupling. I am not convinced there can be enough capacitance to cause a significant or even noticeable shock. I have had this discussion with other "earth ground cultists", but it is too ingrained in their minds.
Stubbie, have you ever heard or read, in your grounding experiences, of anyone ever actually receiving a shock from 120 V through a capcitive-only circuit to earth? I simply do not buy the idea that voltages can swing wildly in reference to the earth on small local systems. Any thoughts?
Old 01-09-2009, 01:47 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
I would agree...it would be highly unlikely if not impossible. Most generator welding electrocutions occur in wet/dry environments when gloves aren't worn and you come in contact with the electrode holder (stick welders) and the work piece when it is bonded with the ground clamp to the generator. But to receive a shock from the welder thru capacitive coupling thru you to dirt is probably not going to happen.
Stubbie
Old 01-09-2009, 03:49 PM   #8
Thanks for the confirmation!!! I really appreciate it.
Tags
generator , ground , welding
Grounded electrode on water pipe TW Lucas Electrical 7 05-12-2008 12:33 PM
Outlets are not grounded...what to do about it? OldHouse963 General DIY Discussions 10 04-14-2008 09:36 AM
yet another welding question amakarevic Tools 4 02-28-2008 10:38 AM
MIG welding amakarevic Tools 28 02-20-2008 09:56 PM
220V Welding Circut Randell Tarin Electrical 10 02-07-2008 10:39 PM
