Does A Washing Machine Need A Dedicated Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 04:42 PM   #1
j_sun's Avatar
Does a washing machine need a dedicated circuit?
Hi All,
Does a washing machine need to be on it's own dedicated circuit? Does it have minimum requirements such as 20A, GFCI etc?
If not, are there any restrictions, regulatory or practical, as to what it can share a circuit with?
Thanks,
Jason
j_sun is offline   Reply With Quote
Old 09-04-2012, 04:53 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,836
I believe the current code reads "Washer and dryer must be fed with it's own dedicated 20A ckt. No other outlets can be on that ckt." Or something like that.
Obviously, if you have an electric dryer, it will have a 240vac outlet.
I'm doing a 2-story addition now that includes a new laungry room....hence I have a dedicated outlet for the washer and gas dryer...and a second outlet on a different breaker for general use in that room.
ddawg16 is online now   Reply With Quote
Old 09-04-2012, 04:57 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
The "laundry" needs a 20A circuit. This can be for the washer, gas dryer, and any other receptacles IN the laundry area.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (09-05-2012), gregzoll (09-04-2012), stickboy1375 (09-04-2012)
Old 09-04-2012, 04:59 PM   #4
Rewards Points: 1,514
The laundry room or alcove needs a 20 amp dedicated circuit run to a 15/20 amp receptacle, a duplex receptacle, or two single receptacles for use by a washing machine. Nothing requires that the washing machine actually be plugged into that circuit.
Old 09-04-2012, 05:03 PM   #5
JOATMON
ddawg16's Avatar
Per the electrical section of my plans....
PROVIDE AT LEAST ONE 20 AMP BRANCH CIRCUIT TO SUPPLY LAUNDRY
RECEPTACLE OUTLETS. SUCH CIRCUIT SHALL HAVE NO OTHER OUTLETS. (CEC
210.11(C)(2))
Old 09-04-2012, 05:10 PM   #6
Resi EC
Rewards Points: 252
[/SIZE][/FONT][/SIZE][/FONT]
There's your problem (CEC)
Local codes may vary from the NEC, it states receptacles in the laundry area may be ran on the same circuit with the clothes washer
Might check for local ammendments
Gac66610 is offline   Reply With Quote
Old 09-04-2012, 05:28 PM   #7
Master Electrician
Rewards Points: 3,876
Probably means the California Electrical Code, not the Canadian Electrical Code.
brric is offline   Reply With Quote
Old 09-04-2012, 06:06 PM   #8
JOATMON
ddawg16's Avatar
Lets see....I live in S California......
Yep.....brric is right....California Electrical Code.....which is basically the NEC....
Old 09-04-2012, 06:23 PM   #9
There may be additional receptacles in the laundry area powered by the "laundry circuit" or by other circuits.
Meaning no outlets in other rooms.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
gregzoll (09-04-2012), zappa (09-04-2012)
Old 09-04-2012, 06:46 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 494
The only requirement for gfci is if you have a sink, and the receptacle will be within 6 feet.
Old 09-04-2012, 07:44 PM   #11
Rewards Points: 3,256
I believe this is the intended meaning.
zappa is offline   Reply With Quote
Old 09-04-2012, 07:46 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Or if your laundry is in a bathroom, very common these days. Just wanted to give another example.
2 Bathrooms on a Single Dedicated 20A Circuit? andy0107 Electrical 5 01-04-2012 02:21 PM
Washing Machine not working..? YellowCar Appliances 2 04-27-2011 08:42 PM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
Dedicated 20amp circuit chingon Electrical 1 03-31-2009 06:36 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
