Does This Romex Need A Staple? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 08:16 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 816
Does this Romex Need a Staple?
Quick question.....
When romex comes out of a hole in a stud this close to the box, does it need a staple?
Old 08-27-2012, 08:17 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ddawg16 View Post
Quick question.....
8" within the box... good reason not to drill so close to the box...
Old 08-27-2012, 09:03 PM   #3
Rewards Points: 12,824
Pull that staple and add a new staple holding both wires.
Old 08-27-2012, 09:18 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Exactly.
That staple in the back is WAY too close to the edge of the stud.
Speedy Petey is online now   Reply With Quote
Old 08-27-2012, 09:22 PM   #5
What's the code, 14" from center of box from the floor and 24" for the wires.
It's been a while and I'm old and forgetful. LOL
Old 08-27-2012, 09:23 PM   #6
E2 Electrician
Code for what? securing?
Old 08-27-2012, 09:23 PM   #7
If you mean drilling there is no code.
Old 08-27-2012, 10:36 PM   #8
Licensed electrician
Rewards Points: 1,020
Unless you are under ADA rules there is no code height for the boxes either.
Old 08-27-2012, 11:22 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 816
I measured the height of my existing outlets in the original part of the house and made these the same.....
Ok....I'll pull the staple and use a double wide.....
So...you think I have my hole too close to the box?
I would have thought with the hole being that close I would not need to secure it...for example....when running a NM cable down the length of a stud, how often do you have to put in a staple?
What are the exact rules on how the wires are supposed to be secured?
Old 08-27-2012, 11:31 PM   #10
For NM cable it needs to be secured within 8" of a box without a clamp or connector or within 12" with a clamp or connector. Thereafter no more than 4.5' between being secured.
Unless the cable is more than 1.25" from the face of the stud nailplates would be required. 3/4" Holes drilled in the center of a 2x4 would not need nailplates.
Old 08-29-2012, 10:05 PM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Quick question.....
No staple required. I do question the bending radius though.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-29-2012, 10:11 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 816
Don't tell me that now......
What is the bending radius limit?
Old 08-29-2012, 10:53 PM   #13
Rewards Points: 324
generaly 12-18 in from floor to top of box is fine for resi.I put mine at 17" to top of box,hole for wire is 23".I know some will say wire waster but easy to staple and work with.
oleguy74 is offline   Reply With Quote
Old 08-30-2012, 01:37 AM   #14
electures's Avatar
5 times the diameter.
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
Staple sizes for Romex? lesp Electrical 2 05-28-2011 06:04 AM
Tore Romex Sheathing Under a Staple....replace the whole wire? jerseyguy1996 Electrical 5 11-01-2010 10:47 PM
# of Romex cables per staple? Tra Electrical 1 10-04-2010 01:21 PM
