Does This Require A GFCI - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 05:20 PM   #16
Originally Posted by HooKooDooKu View Post
So you're saying if the plans for the garage simply stated "we're going to put a referigerator here", but then you never follow through, an non-GFCI outlet would be legal?
If so, I can now understand why 2008 dropped the exceptions.
Yeah...plus houses change hands so the next owner may not use it for that purpose
I think basically they re-thought it & realized that any outlet in a garage could be used outside with an extension cord
Even one on the ceiling for garage door opener...leave a cord plugged in...I mean..how often is a garage door opener used?
I prefer to have the GFCI's...they work
Not 100% sold on the AFCI's yet....but have no choice here
As I understand it from reading other info older fridges/some appliances (12-15 years ?) can still nuisance trip a GFCI
Old 03-05-2010, 06:15 PM   #17
Learning by Doing
Leah Frances's Avatar
I'm sold on GFCIs for fridges after getting a NASTY shock of a fridge with a ground fault. Precautions can be taken to keep GFCIs from being a problem with fridges/freezers.
Omitting GFCIs with fridges/freezers is neglecting caution for HUMAN's safety.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-06-2010, 08:25 AM   #18
I never though about that because I have a ground level outlet in the garage on the outside wall between the doors. But I could see some people doing that that don't have an outlet conveniently located. After all, most recepticals for a garage door opener are going to be the inexpensive standard duplex, so from the get-go you essentially have this wasted plug. Get a $5 extension cord and now you can make use of it.
HooKooDooKu is offline   Reply With Quote
Old 03-06-2010, 11:15 AM   #19
Rewards Points: 160
Thanks guys and gals for correcting me regarding my use of the 2005 code cycle. I use it (2005) because its on the PC and easier than pulling a book out. Even if it were allowed in 2005, its now 2010. So we should all be referencing the 2008 code cycle. I know I will from now on. I just have to get the 2008 on my PC.
Old 03-06-2010, 12:02 PM   #20
Actually your 2005 came in handy since that is the code cycle under which the outlet was installed
I wish I had 05 & 08 on the PC.....that would be so much easier
But can't justify the cost right now
Old 03-06-2010, 12:17 PM   #21
Electrician
Rudeboy's Avatar
Slam a gfi in there. If you have issues with nuisance tripping put a regular receptacle in there and be done with it. if you ever sell the house install the gfi before you sell.
Rudeboy is offline   Reply With Quote
Old 03-06-2010, 12:20 PM   #22
Electrician
Rudeboy's Avatar
Ask me.
Old 03-06-2010, 08:51 PM   #23
Thanks for the input guys. It turns out, the fridge only draws 1.2 amps, so I should be fine tapping into the 15a circuit.
mopowers is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
