Does This Make Sense To You? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 12:39 PM   #1
Rewards Points: 154
Hi,
I have two questions about a panel I recently had an electrician install in my house. We replaced my 100A fuse service with circuit breakers.
First, here's the panel:
My first question is regarding the two circuits that were not long enough to reach the panel. The electrician ran both of these circuits to one box and then ran a 14/3 wire from the box to the panel:
The two hot wires are on separate 15A breakers that are tied together with a bar I'm guessing because it's the same cable(bottom right):
My problem is that one of these circuits is my outside receptacle/lawn lite and the other one is my furnace. From an electrician standpoint while working on someone's house, would you not want to have the furnace completely separate? I want to do some work on my lawn lite and I can't shut the power off without shutting the power to my furnace off too (which means no A/C). This just doesn't seem like a logical thing to do on the electrician's part. Should I call them back and have them put up two junction boxes instead of one?
Secondly, I'm always confused about whether neutral and ground should be tied together in a main panel. They don't appear to be here but I could be wrong:
Thanks for any help
pete0403 is offline   Reply With Quote
Old 05-13-2012, 01:26 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Your electrian created a MWBC (Multi wire branch circuit). Perfectly acceptable method but poor choice of the 2 circuits. Easily fixed. Need to replace the 14/3 with 2 14/2 cables and replace the breaker with 2 single pole breakers. The existing junction box can be used for both circuits.
The main ground and neutral bars are tied together with the buss bar on the left. Not sure why he added the extra bar but it grounded to the panel case.
Coastal South Carolina
Old 05-13-2012, 02:19 PM   #3
Master Electrician
Rewards Points: 3,920
It looks to me that the electrician did an excellent job and that you are creating an issue where none exists.
brric is offline   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
k_buz (05-13-2012), Ravenworks (05-13-2012), Speedy Petey (05-13-2012)
Old 05-13-2012, 02:43 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If those breakers in the top row are on in the down position then he already failed to meet code. I doubt that panel is listed to be mounted sideways like that.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-13-2012, 02:45 PM   #5
Rewards Points: 154
brric, I know he did a good job and I told him that when I happily paid him. Did you read my post? My issue is with the two lines being run together. I can't disconnect my flickering lawn lite until I get a chance to look at the socket without also cutting the power to my furnace.
I understand your kinship to another obviously good electrician here but I'm not creating a problem here. There IS a problem.
Old 05-13-2012, 02:54 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That is standard in Canada.
All you have to do to turn off power to the light is turn off the switch for the light.
The Following User Says Thank You to k_buz For This Useful Post:
brric (05-13-2012)
Old 05-13-2012, 03:08 PM   #7
Sparky
Rewards Points: 510
go buy 10 feet of 14-2, replace the 1 14-3 with 2 14-2's, replace the breaker with 2 single poles, have a beer. $20 worth of material
Techy is offline   Reply With Quote
Old 05-13-2012, 03:20 PM   #8
Rewards Points: 154
Light is on a twilight sensor only. Back to first question...
Should I call him about this our would it be considered "nit picky"?
Old 05-13-2012, 03:24 PM   #9
k_buz's Avatar
Yes nit picky.
If the light is on a photocell, the light is off during the day. If you really want to make sure, flip the breaker for the short while you need to work on the light.
Old 05-13-2012, 03:40 PM   #10
Rewards Points: 506
Send a message via AIM to theatretch85
You could always turn off the breaker for a short time, and disconnect the wire from the breaker that feeds the outdoor circuit, and then turn the breaker back on so the furnace can continue to run. Then when you are done working on the outdoor circuit, turn the breaker off again, re-connect the wire and turn it back on.
theatretch85 is offline   Reply With Quote
The Following User Says Thank You to theatretch85 For This Useful Post:
Old 05-13-2012, 04:11 PM   #11
Master Electrician
Excellent suggestion.
Old 05-13-2012, 04:32 PM   #12
A "Handy Husband"
rjniles's Avatar
Or put a switch in the junction box so you can turn off the outside circuit. How often will you be working on that circuit to make special arrangements.
Can someone explain why the 2 additional ground bars were added (top and bottom of panel) instead of removing the tie bar between the 2 busses and using one for neutral and one for ground? It appears there are more than enough termination holes.
Old 05-13-2012, 05:10 PM   #13
Electrician
Rewards Points: 802
Simple fix, ask him to come put in two single pole breakers instead of the double pole.
I can't find the rule right now, but the breaker tie is only needed when the two hots share the same yoke(i.e stove plug, dryer plug, split plugs).
darren is offline   Reply With Quote
Old 05-13-2012, 05:36 PM   #14
Sparky
Rewards Points: 510
The NEC would require a 2 pole breaker or a handle tie for a MWBC, not sure if the CEC includes this
The Following User Says Thank You to Techy For This Useful Post:
brric (05-13-2012)
Old 05-13-2012, 06:24 PM   #15
Missouri Bound's Avatar
Although I agree with you about the panel, apparently it doesn't matter in Canada.
Do you want it your way or the right way?
How to make recessed shelving DesignDuoBlog How To Guides 0 08-30-2011 04:20 PM
best way to make a small water tank? Red Squirrel Plumbing 22 05-01-2011 06:12 AM
buying my first furnace, does this model/price make sense? skiposwald HVAC 3 04-18-2011 12:11 PM
FREE plans/instructions for easy to make Magic Box! DangerMouse General DIY Discussions 5 07-23-2009 04:14 PM
Does this make any sense? fw2007 Electrical 10 07-24-2008 04:48 PM
