#1 |
does a kitchen have to have a 20A circuit?
Or is a dedicated 15A sufficient for power outlets? Assuming that garbage disposal, DW, fridge all have their own dedicated circuits.
#2 |
Electrical Contractor
In the US, you must have at least (2) 20 Amp circuits for your outlets that serve the kitchen counter areas.
In addition to all that other utilization equipment that you listed.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to kbsparky For This Useful Post: | amakarevic (08-27-2012) |
#3 | |
does a kitchen have to have a 20A circuit?Quote:
#4 | |
E2 Electrician
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to stickboy1375 For This Useful Post: | amakarevic (08-27-2012) |
#5 | |
#6 |
JOATMON
Question....does that MWBC have to be connected to a double breaker with interconnecting handle?
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
E2 Electrician
Depends on the code cycle....
#8 |
JOATMON
#9 |
" Euro " electrician
MDR !!!! ( LOL !!! ) I am more on duex temps ( two cycle ) diesel junkie with screaming Detorits et monster EMD's And I do have Faribanks Morse two cycle diesel engine in my shop back in Wisconsin.
Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
| Display Modes | |
| Kitchen Wiring Clarifications | sullivja | Electrical | 30 | 08-05-2012 09:20 AM |
| Wiring Size Calculations for New Service | CorinthWest | Electrical | 7 | 12-07-2010 12:36 PM |
| Kitchen Sink Moved - new kitchen | sleepysmurf | Plumbing | 1 | 08-10-2010 07:38 AM |
| Changing a 3 way circuit...using recessed lighting box as a junction box? | Oxymoron | Electrical | 1 | 12-07-2009 07:46 PM |
