Old 02-28-2009, 11:54 AM   #1
DIY'er
jamiedolan's Avatar
Does the insulation on old SER cables ever fail?
I am curious if this "insulation" looks like waxed paper on the old SER cables ever fails. If it did, in my main panel, I would clearly have a direct short. After seeing first hand what the results are of a direct short on unfused service, I want to avoid one.
Once I do my service upgrade, this will of corse be gone. I just started thinking, what if one day, my load is a bit on the high side, these conductors get just a little warm and that insulation goes...
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-28-2009, 07:50 PM   #2
Floor Sweeper
I have a hard time believing that it is just the paper wrapping insulating the bare conductors. I would say that you probably have rubber insulation under the wrapping. Cable insulation like that and any other cable insulation is going to be compromised when excessive current flows, but your main breaker "should" trip before you overheat your service conductors.
junkcollector is offline   Reply With Quote
Old 02-28-2009, 10:57 PM   #3
joed's Avatar
Looks like electrical tape recolouring a conductor to me.
Old 02-28-2009, 11:54 PM   #4
GC/Master Plumber/Mech
Looks like to me that the wire are either neutral or grounds in an older load center possible XO box. The white tape on the black is more likely ID for neutral
Old 03-01-2009, 12:03 AM   #5
DIY'er
jamiedolan's Avatar
The cables in question are the large 2awg black and red wires one shown in each photo. The is AL service cable from the meter to this panel. The white that is taped is a piece of thhn feeding my sub panel I installed.
Jamie
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 23 06-05-2011 11:57 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
