Does A Household Circuit Breaker Have Thermal Memory? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 06:27 AM   #31
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by k_buz View Post
I don't think Square D panels have any protection from installing tandems. Every Square D panel I have been in could physically fit tandem breakers even if the panel wasn't listed to.
They definitely do. More than one type too. The newer one have a huge hook where the outboard "snap" is.
Old 02-10-2013, 07:25 AM   #32
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I didn't know that, but then again, I don't try in install a tandem without the space being rated for it.
Old 02-10-2013, 07:57 AM   #33
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
When I buy a Square D tandem they the picture below. That one is some generic replacement that may or may not be listed for the panel. I would verify that the circuit is 12 gauge wire and replace the breaker with a 20 amp single pole breaker.
Keep the trunk slammers out of your panel and hire a reputable electrician. That guy was just around to make a quick buck. Just used something he had laying around. I actually found a breaker that looks like the one he used they sell for 20. He could have installed a single square d breaker for 10.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-10-2013, 11:13 AM   #34
Pro
Rewards Points: 91
I agree with the caution about trunk slammers, but it's not certain that that breaker is a generic or counterfeit. QO breakers don't necessarily have the logo on the front - the SquareD on-line catalog shows a QOT that looks just like the one in the poster's photo. Reading about QO counterfeiters on-line, the logo on front or absence of it, isn't conclusive. Whether the logo and other info is stamped on the side is conclusive. I checked into this a while back when I was working on a QO panel with some breakers with logos and some without. It appeared to me that the breakers that came from the big box store didn't have the printed logo on front, and the ones from the local electrical supply did.
Whether it's a counterfeit or not, it should be replaced with a single, sized correctly for the circuit.
CarpenterSFO is offline   Reply With Quote
Old 02-10-2013, 11:29 AM   #35
Pro
Rewards Points: 91
The clue if any that it's a counterfeit is that the amp rating on the handle isn't painted white. After 2003, all QO breakers have the rating painted white. So it's either counterfeit, or older. I suspect that it's an older, possibly used, breaker that was kicking around in the guy's truck.
Old 02-10-2013, 02:41 PM   #36
Update: I decided to replace the breaker myself this morning. I replaced it with a 20A single pole. Everything went well. Here are some photos of the breaker that the "handyman" installed. It was obviously used. To help answer my original question I disassembled the breaker. Photos posted.
Thanks for all the comments.
does a household circuit breaker have thermal memory?-img_0154.jpg   does a household circuit breaker have thermal memory?-img_0159.jpg   does a household circuit breaker have thermal memory?-img_0161.jpg   does a household circuit breaker have thermal memory?-img_0165.jpg
djmieczk is offline   Reply With Quote
The Following User Says Thank You to djmieczk For This Useful Post:
CarpenterSFO (02-10-2013)
Old 02-10-2013, 02:46 PM   #37
Can someone confirm if this breaker has a thermal/electomagnetic design? I see the electromagnet but I am not sure if there is a bi-metallic element in this design.
Old 02-10-2013, 02:59 PM   #38
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yep it does see red arrow in diagram ...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following 2 Users Say Thank You to Stubbie For This Useful Post:
CarpenterSFO (02-10-2013), djmieczk (02-10-2013)
Old 02-10-2013, 05:33 PM   #39
Pretty much ALL "modern" breakers have both thermal and magnetic trip.
Old 02-10-2013, 06:53 PM   #40
Rewards Points: 980
My house was built in 2006. Out of 30 someodd Square D breakers, only the AFCI, GFCI, and 240v breakers are white. The rest are black.
I doubt the contractor had 3 year old stock, and I hope he didn't use counterfit.
Interestingly, there are two Siemens breakers; I didn't know they made them to fit Square D.
Toller is offline   Reply With Quote
Old 02-10-2013, 06:59 PM   #41
Rewards Points: 980
Are you saying the older tandems don't have the hook?
In the unlikely case I was able to locate an old one, what would the harm be in using a tandem in a box not intended for it?
In a post a few months ago (maybe not here, I don't remember) I said that I was short on space and my box wouldn't take tandems. One reply was that he just cut the hook off and all was well; but that just doesn't seem like a great idea.
Tags
circuit breaker
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
circuit breaker? blueandyellow Electrical 7 01-30-2011 10:27 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 05:11 AM
