Does It Exist - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 08:47 PM   #1
Rze
Average Joe
Rewards Points: 79
Does it exist
Looking to find out is a cable exist that has at least 7 wires.....Looking to create a snake that has three plugs on one end associated with three receptacles on the other end. basically three extension cords in one run.
Rze is offline   Reply With Quote
Old 10-12-2008, 08:58 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
I'm sure it exists, but good luck finding any.
Speedy Petey is online now   Reply With Quote
Old 10-12-2008, 09:04 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Multi ended extension cord
Jamie
jamiedolan is offline   Reply With Quote
Old 10-12-2008, 09:10 PM   #4
Rewards Points: 2,350
A piece of half-inch "seal tite" conduit with boxes on each end. You can pull the conductors in yourself, and terminate whatever connectors you need at the boxes.
Old 10-12-2008, 09:34 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
RZE, how many times are you going to ask the same question? Multiple solutions have been provided here in the past threads you have started.
theatretch85 is offline   Reply With Quote
Old 10-12-2008, 09:37 PM   #6
DIY'er
jamiedolan's Avatar
LOL I didn't even realize it was the same poster!
I like the seal tight solution. I bet stranded would hold up better to extension cord type of use.
Jamie
Old 10-12-2008, 09:58 PM   #7
Here ya go...
Belden 8628 7 conductor cable - 14 AWG
$1,730.57 (Per 500 ft. Coil)
http://www.alliedelec.com/Search/Pro...x?SKU=216-2398
Billy_Bob is offline   Reply With Quote
Old 10-12-2008, 10:42 PM   #8
Rze
Average Joe
Rewards Points: 79
Sorry
My bad....i knew I had asked someone this question before....Wasn't till you pointed it out that I realized why it was so familiar!!! No need to get upset. Thanks for pointing me backwards!
Billy_bob.....holy cow!!!!!
Old 10-12-2008, 10:55 PM   #9
Well that is a start. Might want to contact Belden and ask if someone near you sells this by the foot.
http://www.belden.com
Old 10-14-2008, 08:32 AM   #10
An old Tradesmen
Rewards Points: 7,826
They make 14/7NM
Old 10-14-2008, 03:15 PM   #11
Advice worth 2 cents!
Rewards Points: 150
Where do you want to use this cable? If a rubber extension cord will do, the stuff comes in any number of conductors (go to an electrical supply warehouse)
---pete
HandyPete is offline   Reply With Quote
Old 10-14-2008, 03:22 PM   #12
An old Tradesmen
Guessing your refering to SJO cord.
Old 10-15-2008, 05:58 PM   #13
cable
Lots of this stuff used in the entertainment industry, which is what you want it for. Check the link below or google "socopex cable" (a kind of connector). You can buy just the cable (commonly in 16, 14, or 12 guage) or many companies will make up whatever finished cable you want. This stuff is used for portable lighting because it is MUCH lighter than SJO cord.
http://www.globalspec.com/FeaturedPr...r_Veam/38952/1
garyoutwest is offline   Reply With Quote
Old 10-15-2008, 06:46 PM   #14
Rewards Points: 506
Wow, completely forgot about socapex cable! That would be the way to go (if you can afford it) since most socapex cables I have seen will run 6 circuits.
BTW, 100' of socapex cable is NOT light! I work for a company that owns 10 100' socapex cables and an assortment of 50's and 25's.
Old 10-15-2008, 07:18 PM   #15
That's true, theatretech, but before this kind of cable, mults were often made of 'elevator hoist' cable. Much heavier, not much better than a hod of 12/3 sjo. If you work for a company doing that kind of work, you probably get to muscle around some lengths of 4/0 type W as well .
Does this window exist? ClnlBrahm Building & Construction 4 09-19-2008 04:30 PM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
Do these exist? (stone tiles that aren't square) joeyboy Flooring 3 04-11-2007 12:38 PM
Double-pole 3-way switch exist? bob12 Electrical 1 01-08-2006 11:02 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
