-   -   Does it exist (http://www.diychatroom.com/f18/does-exist-29833/)
Rze 10-12-2008 08:47 PM
Does it exist
Looking to find out is a cable exist that has at least 7 wires.....Looking to create a snake that has three plugs on one end associated with three receptacles on the other end. basically three extension cords in one run.
Speedy Petey 10-12-2008 08:58 PM
I'm sure it exists, but good luck finding any.
jamiedolan 10-12-2008 09:04 PM
http://www.diychatroom.com/f18/multi-ended-extension-cord-27168/
Jamie
InPhase277 10-12-2008 09:10 PM
A piece of half-inch "seal tite" conduit with boxes on each end. You can pull the conductors in yourself, and terminate whatever connectors you need at the boxes.
theatretch85 10-12-2008 09:34 PM
RZE, how many times are you going to ask the same question? Multiple solutions have been provided here in the past threads you have started.
jamiedolan 10-12-2008 09:37 PM
LOL I didn't even realize it was the same poster!
I like the seal tight solution. I bet stranded would hold up better to extension cord type of use.
Jamie
Billy_Bob 10-12-2008 09:58 PM
Here ya go...
Belden 8628 7 conductor cable - 14 AWG
$1,730.57 (Per 500 ft. Coil)
http://www.alliedelec.com/Search/Pro...x?SKU=216-2398
Rze 10-12-2008 10:42 PM
Sorry
My bad....i knew I had asked someone this question before....Wasn't till you pointed it out that I realized why it was so familiar!!! No need to get upset. Thanks for pointing me backwards!
Billy_bob.....holy cow!!!!!
Billy_Bob 10-12-2008 10:55 PM
Well that is a start. Might want to contact Belden and ask if someone near you sells this by the foot.
http://www.belden.com
beenthere 10-14-2008 08:32 AM
They make 14/7NM
HandyPete 10-14-2008 03:15 PM
Where do you want to use this cable? If a rubber extension cord will do, the stuff comes in any number of conductors (go to an electrical supply warehouse)
beenthere 10-14-2008 03:22 PM
Guessing your refering to SJO cord.
garyoutwest 10-15-2008 05:58 PM
cable
Lots of this stuff used in the entertainment industry, which is what you want it for. Check the link below or google "socopex cable" (a kind of connector). You can buy just the cable (commonly in 16, 14, or 12 guage) or many companies will make up whatever finished cable you want. This stuff is used for portable lighting because it is MUCH lighter than SJO cord.
http://www.globalspec.com/FeaturedPr...r_Veam/38952/1
theatretch85 10-15-2008 06:46 PM
Wow, completely forgot about socapex cable! That would be the way to go (if you can afford it) since most socapex cables I have seen will run 6 circuits.
BTW, 100' of socapex cable is NOT light! I work for a company that owns 10 100' socapex cables and an assortment of 50's and 25's.
garyoutwest 10-15-2008 07:18 PM
That's true, theatretech, but before this kind of cable, mults were often made of 'elevator hoist' cable. Much heavier, not much better than a hod of 12/3 sjo. If you work for a company doing that kind of work, you probably get to muscle around some lengths of 4/0 type W as well :(.
