Does Every Metal Box Need To Be Grounded? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 08:26 AM   #46
Licensed electrician
Rewards Points: 1,762
The box cannot be bonded by the 6-32 if the device is grounded.
A device may be grounded if the box is grounded under certain conditions.
Old 09-12-2012, 09:32 AM   #47
Originally Posted by amakarevic View Post
I was wondering if every metal receptacle need to be grounded via a green ground screw screwed in a hole in the back and connected to the other ground wires coming into and out of the box, in addition to the ground terminal of the possible power outlet or light for which the box is used. Also, if the box is used only as a JB, does it still need to be grounded?
I think all of his questions have been answered, but not in one post. I'll attempt to do that.
By receptacle, the OP meant box. It was also established that the ground/bond screw does not have to be green. It also is implied in the answers that it is no good to just put in a screw if you do not connect it back to the grounding conductor coming into the box. The question is, "Does every metal box need to be grounded via a screw in the hole in the back of the box?" For safety, yes.
...in addition to the ground terminal of the possible power outlet or light for which the box is used.
If the "device yoke" is in contact with the metal box, then you probably do not need to run a ground wire to the device's ground screw. But if in doubt, running the extra conductor will not do any harm.
I would ground the junction box for the same reason as in question #1. If the bare hot wire comes in contact with the metal box, someone touching the box could receive a nasty shock. In the junction box, you'll wire nut the ground conductors anyway. Just add one more as a jumper/pigtail to the box's ground screw.
brgmgb is offline   Reply With Quote
The Following User Says Thank You to brgmgb For This Useful Post:
amakarevic (09-12-2012)
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Combining old wire to new Cossack Electrical 148 08-26-2012 01:56 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 06:37 AM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Grounded electrode on water pipe TW Lucas Electrical 7 05-12-2008 11:33 AM
