Does A Dishwasher Need It's Own Dedicated Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 08:18 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by flyboy2610 View Post
if the manufacturer specifies it, and you don't do it, you've voided the DW warranty.
I highly question this.
Speedy Petey is online now   Reply With Quote
Old 02-21-2009, 08:19 AM   #17
Electrician
Me too, most likely anything you read in a manual is just an opinion of the manufacture. And not actually part of the listing. sort of a CYA....
chris75 is offline   Reply With Quote
Old 02-21-2009, 08:54 AM   #18
Hey All, thanks for all your great response & feedback on this... I didn't realize there are such differing opinions on the topic. I was just looking for the "proper" way to do this as opposed to... "it's ok, but..."
It looks like Jamie is right in regards to the "manufactures specs". I stumbled upon a Frigidaire DW installation guide (see attached) and it does clearly states..
"The dishwasher operates on a 120 volt, 60 Hz electrical supply.
Provide a separate circuit with a fuse or circuit breaker rated for
at least 15 amps (20 amps if connected with disposer) but not
more than 20 amps."
Again... i do not own the dishwasher yet so I have no idea what brand i will end up with but, I assume most manufacturers would require a similar setup. So this leads me to assume that adding an outlet to this / although doable / would not be recommended as what ever is plugged into that outlet is unknown and "may" overload the circuit depending on it's draw. So.. with that said I may have to do without. I wish i found this forum before i started to run that wire!
OK.. now for a different question..
After reading the manufacturer spec / i noticed that these DW units are hard wired!?
So why did my electrician cap the line with an outlet as opposed to leaving just the cable?
This sucks as i dont think i have enough slack to hard wire this within the area specified by the manufacturer!
Do i have to open up this wall "AGAIN"!
I'm also concerned by the location of the electric on the wall as it does not line up with what is recommended (again see atached).
Does this need to be addressed as well / not much clearance their (2-3/4"?) / is that right?
This is becoming frustrating FAST!
Casey_Oakland is offline   Reply With Quote
Old 02-21-2009, 09:15 AM   #19
Electrician
All appliances need a disconnect, a cord and plug meets this requirement, so just install a cord on the DW, I always install them in the sink cabinet.
Old 02-21-2009, 09:20 AM   #20
So by adding a cord i could just plug a dishwasher into an outlet like any other appliance?
Does it mater it's not located in the "gray area" as the spec sheet shows?
Freaking confused
Old 02-21-2009, 09:22 AM   #21
Electrician
Originally Posted by Casey_Oakland View Post
You mean dish washer right ; )
Freaking confused
If the receptacle is not in the gray area, you'll probably have some issues... This is why I install them in the sink cabinet...
Old 02-21-2009, 09:27 AM   #22
crap!
1 step forward... 18 steps back!!
So to sum up / No extra outlet!
and now i have to move the existing DW outlet down!?
My head is going to blow up!
Old 02-21-2009, 09:37 AM   #23
Electrician
If it was easy, everyone would be doing it.
Old 02-21-2009, 09:45 AM   #24
true, true.
Thanks Chris for the help.
I'll grin and and bear it i guess
Not happy about it but at least i know it's done proper and will hopefully save extra work later when I begin the install.
Appreciated!
Old 02-21-2009, 10:28 AM   #25
Licensed Pro
The receptacle is typically installed in the adjacent cabinet (under sink) and is split... bottom switched for disposal and top always hot for dishwasher. A cord and plug is connected to the dishwasher (and disposal) and each is plugged into their respective receptacle.
Old 02-21-2009, 10:43 AM   #26
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
This is exactly what I just did for my partents a heavy duty p&s 20a with tab broken out top switched for disposal. Fed with a mwbc via thhn in smurf, neural pigtailed then to the outlet. I made a cord for the dw with 12 gage sjoow.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-21-2009, 10:48 AM   #27
If its not in the gray area the dishwasher will hit it
This could be slightly different for each dishwasher
I think the limit is a 6' cord on the dishwasher
You could still hardwire the DW in with a short piece of wire going into the outlet. I prefer cord & plug - much easier to move & disconnect power if you need to work on something or troubleshoot
Old 02-21-2009, 10:55 AM   #28
DIY'er
jamiedolan's Avatar
It needs a means of disconnect, if it is hardwired, that is normally a switch. Snips don't count as a means of disconnect.
Jamie
Old 02-21-2009, 11:19 AM   #29
Rewards Points: 2,350
Jamie
The branch breaker is the means of disconnect.
Old 02-21-2009, 01:00 PM   #30
Electrician
I see lots of hard wired DW's around here, just nobody installs the required breaker lock... I doubt they know its required.
Microwave dedicated circuit? DIYGST Electrical 2 12-03-2008 02:08 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Dedicated circuit for washer/dryer TVC15 Electrical 4 07-27-2008 10:42 PM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 03:09 PM
dedicated circuit for smoke detectors wiggs Electrical 11 04-24-2006 08:25 PM
