Does A Dishwasher Need It's Own Dedicated Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 01:55 PM   #1
Does a Dishwasher need it's own dedicated circuit?
I have a dedicated 20 amp circuit in my kitchen meant for a dishwasher.
Can I run an electrical outlet off that same circuit? I live in Mass if that makes a difference in regards to code?
Ideally i would like to run an AC unit in the summer off that outlet but I can understand if this is not feasible.
Would it be better to jump off a counter top GFI to create the new outlet?
Any advice is greatly appreciated.
Thanks!
Casey_Oakland is offline   Reply With Quote
Old 02-20-2009, 02:56 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Thanks!
Counter top outlets are dedicated for the counter tops and you can not tap off of them for anything but the counter top.
It would almost surely overload the dishwasher circuit to have an AC unit and dishwasher on the same circuit. It is not required by code to have a dishwasher on it own circuit, but you must follow the manufactures directions for a legal install. I just installed a Dishwasher and it specifically stated it needed it's own 15A circuit.
Even a modern AC unit is a fairly heavy load, you really should run a new circuit from your panel to avoid tripping breakers and have a legal install.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-20-2009, 03:16 PM   #3
Thanks Jamie for your reply!
I figured as much in regards to the AC unit : /
So i take it as long as I keep the load to standard appliances I should be ok?
Old 02-20-2009, 03:17 PM   #4
Mine is on with the garbage disposal, actually had no clue! Never have tripped the breaker. But I would just run 12/2 on a 20 amp breaker.
The counter top outlets cannot be tapped off by code.
rgsgww is offline   Reply With Quote
Old 02-20-2009, 03:25 PM   #5
Res Ipsa Loquitur
Mine has d/w together with disposer and never been a problem since they rarely have a major draw of electric at the same time!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-20-2009, 03:28 PM   #6
yeah..
Thats what i set up / jumping 12/2 off the originally dedicated 20 amp from the dishwasher for the new outlet.
Just wanted to double check if this is legit.
Running a new dedicated line isn't really an option for me.
If anything i would just scrap the outlet if not safe.
Old 02-20-2009, 04:32 PM   #7
Electrician
Here is the code section if anyone is really interested....
210.23 Permissible Loads
In no case shall the load exceed the branch-circuit ampere rating. An individual branch
circuit shall be permitted to supply any load for which it is rated. A branch circuit
supplying two or more outlets or receptacles shall supply only the loads specified
according to its size as specified in 210.23(A) through (D) and as summarized in 210.24
and Table 210.24.
(A) 15- and 20-Ampere Branch Circuits
A 15- or 20-ampere branch circuit shall be
permitted to supply lighting units or other utilization equipment, or a combination of
both, and shall comply with 210.23(A)(1) and (A)(2).
Exception: The small appliance branch circuits, laundry branch circuits, and bathroom
branch circuits required in a dwelling unit(s) by 210.11(C)(1), (C)(2), and (C)(3) shall
supply only the receptacle outlets specified in that section.
(1) Cord-and-Plug-Connected Equipment Not Fastened in Place
The rating of any
one cord-and-plug-connected utilization equipment not fastened in place shall not exceed
80 percent of the branch-circuit ampere rating.
(2) Utilization Equipment Fastened in Place
The total rating of utilization equipment
fastened in place, other than luminaires (lighting fixtures), shall not exceed 50 percent of
the branch-circuit ampere rating where lighting units, cord-and-plug-connected utilization
equipment not fastened in place, or both, are also supplied.
chris75 is offline   Reply With Quote
Old 02-20-2009, 04:40 PM   #8
DIY'er
jamiedolan's Avatar
Chris, Question / clarification; If the Dishwasher Manufacture specifics the unit to have a dedicated 15a or 20a circuit, then you must comply with the manufactures directions regardless of available capacity based on 210.23, correct?
Jamie
Old 02-20-2009, 04:43 PM   #9
Can someone translate these codes for me?
Is this legit or not? Or does this all depend on the manufacturers specifics of a particular DW unit?
How would I find this out before hand? I dont own the DW yet..
This will go along way in advicing how this should be setup.
Much Thanks all!
Old 02-20-2009, 04:44 PM   #10
Electrician
Jamie
Lots of debate with that one, because its probably not actually part of the listing of the equipment...
Old 02-20-2009, 06:43 PM   #11
DIY'er
jamiedolan's Avatar
Much Thanks all!
Legit, maybe, I think we would all have to say it is going to be a call that your local building / electrical inspector would have to make when you take out a permit.
A good idea, no, as I mentioned at first, it is almost certain to be too heavy of a load if they both run at once.
Running a new circuit is really the best choice here. If you can't do it yourself, most of the time it's something an experienced individual / electrician could do within a couple hours.
In most cases, I could manage to get a new circuit to a new outlet just about anywhere in a home in half a day or less, very possibly with no damage to walls.
You may want to call an electrician, it may only be a couple hours of work for someone with the right tools.
Jamie
Old 02-20-2009, 06:59 PM   #12
I really hate a dedicated circuit for something only used once a day
But I guess we have lots of dedicated circuits for similar items
AC's, fridge, tub heater etc
If you had a 20a circuit & the dishwasher used less then 10a (1200w) then you could have another outlet or device. I'd have to see what the DW pulled for power
Also check to see if the DW has a pre-heater
That is usually a good idea
Old 02-20-2009, 07:04 PM   #13
DIY'er
jamiedolan's Avatar
Why would you hate dedicated circuits where needed or beneficial? Cost is minimal.
I really hate breakers tripping. Dedicated circuits where appropriate are a wonderful way to eliminate many over current trips.
Jamie
Old 02-20-2009, 07:07 PM   #14
Cost is minimal, panel space is not minimal
With all the dedicated circuits you need a sub on almost every decent sized house these days.
They need bigger panels
Maybe they already make them?
I saw a huge one - Canadian installation I think
It was awesome!!!
Old 02-20-2009, 08:55 PM   #15
Crazy, but lovable
flyboy2610's Avatar
Even if code does specifically require that a dishwasher have it's own circuit, if the manufacturer specifies it, and you don't do it, you've voided the DW warranty.
flyboy2610 is offline   Reply With Quote
Microwave dedicated circuit? DIYGST Electrical 2 12-03-2008 03:08 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Dedicated circuit for washer/dryer TVC15 Electrical 4 07-27-2008 11:42 PM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 04:09 PM
dedicated circuit for smoke detectors wiggs Electrical 11 04-24-2006 09:25 PM
