Old 09-25-2010, 09:44 AM   #1
Does ceiling fan screw-type matter?
I know ceiling fans need to be mounted to ceiling fan-rated support and boxes with 10-32 screws. My question is, can any 10-32 screw suffice? I ask because my fan instructions say to only use the screws provided with the box, but the ones in the box are too short to do me any good. These are the same instructions that told me to use electrical tape on every wire nut which, while not hurting anything, does not do much (at least that's my understanding). Anyway, I bought some longer 10-32 machine screws which are pretty much identical except they actually feel a little stronger (heavier), don't have the screw tip slightly cutaway, and they don't have ridges under the screw head. Any problems with using these instead?
DIYnewbie9 is offline   Reply With Quote
Old 09-25-2010, 09:58 AM   #2
the Musigician
DangerMouse's Avatar
I see no problem, I'd probably use lock washers to compensate for the lack of 'ridges' under the heads.
This keeps the screws from vibrating loose.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-25-2010, 07:29 PM   #3
As DangerMouse said, vibration is bad. Take the extra time after blade install to balance/reposition blades so nearly no vibration is end result. Use provided weights as necessary, or a penny, or a dime etc. Fans with no shaft are easier. Fans with a shaft extending from ceiling may need balancing.
diyorpay is offline   Reply With Quote
Old 09-26-2010, 11:03 AM   #4
Licensed electrician
The ears on the box should not be that far back from the surface that the provided screws are too short. The box is only allowed 1/4" recessed from a non-combustible surface.
Most of the 10-32s provided with the brackets are also a tri-oval shape.
Old 09-26-2010, 11:14 AM   #5
I guess because of the thickness of the drywall the new ceiling fan-rated box (the kind with the extendable support bar) sits more than 1/4 from the drywall surface. I am aware of the 1/4" requirement and am using a plastic box extender to cover the gap. I have it as ceiling fan-rated box and support bar, plastic extention ring, and then fan mount screwed in with longer 10-32 screws and a split ring lock washer.
Trey (aka tray) raised ceiling with lights. kaciuba Building & Construction 0 06-01-2010 10:51 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
gas line vs screw wobblybowl Plumbing 5 05-27-2009 11:49 PM
Ceiling Fan Downrod type needed? darenka Electrical 5 04-21-2009 07:43 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 11:13 PM
