Does Armoured Cable Need To Be Clipped? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 03:02 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
does armoured cable need to be clipped?
I had to run 6 feet of armoured cable up the wall and into the top of my hot water tank, Does it need to be clipped to the way every certain feet like romex at all?
ryanh is offline   Reply With Quote
Old 08-01-2010, 03:47 PM   #2
Master Electrician
according to 12-706 (2) it says 2m between supports. if needed adjacent to termination fittings. If you put a clip around a foot from the junction box then another where you come off the wall and go to the tank you should be good. I like to put lots of clips...makes a neater and straighter job, looks more professional and all for the cost of a few cents.
i should point out that that's taken from the ontario code book so it could be longer in your area.
andrew79 is offline   Reply With Quote
Old 08-01-2010, 04:23 PM   #3
" Euro " electrician
frenchelectrican's Avatar
For 2m of amoured cable yeah it is will be wise to put a clip on the wall the first clip about 30cm from the junction box then second one depending on how far the cable run down something like half meter before it will bend out from the wall to the waterheater tank but do NOT make super sharp bend they just don't like it at all so make a smooth bend.
Merci.
Marc
Old 08-02-2010, 01:10 PM   #4
ryanh's Avatar
Rewards Points: 154
Cool.. The cable is all run on the outside of the drywall through. I can check if theres any studs around if not i guess use wall anchors?
Old 08-02-2010, 09:00 PM   #5
Oui { yes } if you can not find the stud then use the wall anchors.
Merci.
Marc
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
