Does Anybody Reuse Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 08:40 PM   #1
Rewards Points: 43
Does anybody reuse wire?
Hello, I am redoing the lower level of my split level house, part of which is the family room. I want to reframe it, rewire, and then drywall it properly. No more faux wood paneling!
It was built in 1966, and they used 12-2 romex to wire it. However it doesn't quite look like the romex that I can buy in 2010. The black and white wire are 12 gauge, however the ground is a green wire which is 16 gauge. Not the bare 12 gauge wire used in today's romex.
What I tend to normally do is throw everything away, or to the scrap yard, and then start over. However then part of me thinks that's over kill and it would be just fine to reuse.
Any suggestions on if it's OK to reuse this wire? Thanks for reading and any input.
jobblyman is offline   Reply With Quote
Old 10-26-2010, 09:03 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
No way I'd re-use that.
Old 10-26-2010, 10:00 PM   #3
Mabc's Avatar
Get new wire!
Mabc is offline   Reply With Quote
Old 10-26-2010, 10:03 PM   #4
Rewards Points: 43
Thanks for the advise! I was strongly leaning towards new wire, however I sometimes tend to overdue things so was not sure. A trip to the scrap yard then Home Deopt!
Old 10-26-2010, 10:27 PM   #5
" Euro " electrician
frenchelectrican's Avatar
It is far less trouble and aggravation to just get new cable than try to mess around with old cable.
And it much quicker for us anyway.
Merci.
Marc
Old 10-26-2010, 10:41 PM   #6
RST
DIY Homeowner
Rewards Points: 150
Can old cable be recycled? As I'm rewiring it seems like a waste to just throw it out.
RST is offline   Reply With Quote
Old 10-26-2010, 10:43 PM   #7
Oui you can able recycle at the salvage yard the amout they will pay ya in pounds of copper so the actual price will varies from each location and the day due the market price will fulacting so one day may have good price then next day may drop a bit so check around.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
RST (10-27-2010)
Old 10-26-2010, 10:59 PM   #8
Rewards Points: 43
yup, I rewired my both my bathrooms and my kitchen. It doesn't pay as much as taking in copper pipes to the scrap yard, but I received 17 bucks for something I was all too happy to throw away...
The Following User Says Thank You to jobblyman For This Useful Post:
RST (10-27-2010)
Old 10-26-2010, 11:30 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,152
If you have ANY doubt,
dont reuse it.
due to the age alone,
I would not re use it.
dmxtothemax is offline   Reply With Quote
Old 10-27-2010, 06:49 AM   #10
Rewards Points: 43
When in doubt, throw it out!
Old 10-27-2010, 07:07 AM   #11
the Musigician
DangerMouse's Avatar
Reduced ground wiring is no longer legal to use around here, (or anywhere I think). I DID re-use some of the 12g I had though, I just stripped out the white wire and colored it green to use as a ground.... It was for a light switch I added after the rough-in, but the inspector said it'd be fine.... WITH the 12g ground.
DM
Old 10-27-2010, 07:59 AM   #12
Just call me Andrew
Rewards Points: 1,020
If you're buying lots of wire, you may want to check pricing at a local electrical supply house. I just did that (for only 100' of 14/2) and it saved me like 5 bucks.
I thought it was "When in doubt, kick it out!"...
Wait, maybe that was recreational soccer...
Andrew
secutanudu is offline   Reply With Quote
Old 10-27-2010, 08:04 AM   #13
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,336
As I'm doing my rebuild, I've re-used wire for temporary outlets but not for circuits that are permanent.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
