Does 240v Use Less Energy Than 120v? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 01:51 PM   #1
Does 240v use less energy than 120v?
Does a 240v air compressor use less energy than a comparable 120v unit?
mopowers is offline   Reply With Quote
Old 03-10-2010, 01:55 PM   #2
Just call me Andrew
Rewards Points: 1,020
I'll take a shot at this:
Volts (pressure) x Amps (size of line) = Watts (energy used)
A 240v/20a device would certainly use more than a 120v/21a device.
Think of it like water:
75 PSI in a 1" pipe uses more Gallons Per Minute than 25 PSI in a 1" pipe.
Right?
Andrew
secutanudu is offline   Reply With Quote
Old 03-10-2010, 02:07 PM   #3
No...
A 240V air compressor has the "potential" to use more energy than a 120V model but that is not always the case.
Check the nameplate to see either the watts or the current of the device. As secutanudu mentioned...
Energy = Watts
Energy = Voltage * Current
DownRiverGuy is offline   Reply With Quote
Old 03-10-2010, 02:13 PM   #4
Master Electrician
Rewards Points: 3,768
Originally Posted by DownRiverGuy View Post
No...
Energy = Watts
I agree. A watt is a watt. 2400 watts @ 240 volts is the same as 2400 watts @ 120 volts.
Power is measured in watts.
brric is online now   Reply With Quote
Old 03-10-2010, 02:20 PM   #5
So if you've got a compressor that is capable of running on either 120 or 240, are you better off running on 120 or 240? I assume the motor would run more efficiently on 240. What do you folks think?
Old 03-10-2010, 02:24 PM   #6
Master Electrician
Right?
You have to compare the same devices or equipment. In your example you would need a 120 volt device that draws 40 amps not 21 amps.
When you double the voltage the amperage decreases by 50%
A certain motor uses 4800 watts. Wired for 240 volts it will draw 20 amps. Wired at 120 volts it wil dra 40 amps.
Old 03-10-2010, 02:26 PM   #7
Master Electrician
The issue becomes voltage drop and wire size. 240 volt motors can be supplied with lower amperage circuits than the same motor using 120 volts
Old 03-10-2010, 02:34 PM   #8
Just call me Andrew
I stand corrected! I had a feeling it was more complicated than it seemed.
Andrew
Old 03-10-2010, 02:38 PM   #9
Master Electrician
No problem. I consider it a bad day if I don't learn something new each day.
Old 03-10-2010, 02:52 PM   #10
Thanks for the replies! Do you think the difference in voltage drop would be significant?
Old 03-10-2010, 02:59 PM   #11
Master Electrician
Depend upon how far the unit is from the elecrical panel and upon the current draw of the compressor.
Let me ask. Do you even have 240 volts available at the location where you intend to use the compressor?
Old 03-10-2010, 03:19 PM   #12
I actually have a 240v compressor in my garage already. I just started this thread as a hypothetical question.
My compressor is pretty far from the panel (say 75 feet). The circuit I have is rated for 50 amps and uses aluminum wire, however I replaced the breaker with a 30a breaker as recommended by the compressor mfg.. The compressor draws 17amps I believe. What would be the voltage drop on this circuit? What about if it were wired into a 120v circuit w/ 10-2?
Old 03-10-2010, 03:30 PM   #13
Experienced goon
http://www.csgnetwork.com/voltagedropcalc.html
jpelzer is offline   Reply With Quote
Old 03-10-2010, 03:46 PM   #14
Master Electrician
What is Al wire size?
If 17 amps is the draw@240 volts then the draw would be 34 amps @120 volts.
Need the wire size to calculat voltage drop.
Old 03-10-2010, 04:04 PM   #15
I'm not sure of the wire size. But it would be whatever size needed for a 50amp circuit. I do know that the wire is aluminum. It looks really big to my untrained eye.
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 05:05 PM
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 12:29 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 10:50 PM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 10:15 AM
Cattle waterer 240V - also need 120v! 2wheelinusa Electrical 6 10-05-2008 07:39 PM
